XR4150 no throttle, failure codes, difficulty w / LS support
   / XR4150 no throttle, failure codes, difficulty w / LS support #1
stump020500
AR
LS 4150H
I've got a 2018 XR 4150H. A great tractor, until now. In the short term, confusing at best, frustrating in the least.
Started brush hogging. After about 30 min. went into reduced power mode. Fault codes
29 31 P2138 Hand Pedal Correlation track 1 over track 2 fault
29 31 P060E Hand pedal signal fault
29 31 P2120 Hand pedal signal track 1 fault
29 31 P2125 Hand pedal signal track 2 fault
81 11 P242F DPF fault triggers reduced torque
Pulled over, initiated forced regen.
Regen was as normal.
Warranty date close, but not sure.
It took 2 phone calls, an email and FB message to get response from LS re: s/n and warranty date.
Murphy's law. B to B warranty expired one month ago today.
"Hand Pedal" fault seems to indicate "Hand Throttle Lever".
Was informed by LS that the "Hand Throttle Lever" would not be under the power train warranty (regrettably makes sense) and If I did buy the part and self install, it would still likely need to be calibrated by a dealer.
Cleaned grounds, known factory issue. Grounds were, as expected, painted. Sanded clean. No joy.
Compounding issue is that selling dealer is 800 miles away.
The one bright spot is that a local dealer 45 miles away did give me one other thing to try before loading it on the trailer and bring it to him.
Any thoughts?
Thanks
   / XR4150 no throttle, failure codes, difficulty w / LS support #2
Have you done a visual inspection under the tractor? Since that happened while you were brush hogging, I wouldn't be surprised if the brush or a stick pulled some wires or knocked something under the tractor.
   / XR4150 no throttle, failure codes, difficulty w / LS support #3
Which dealer are you working with?
Good suggestion. But, yes, everything is still connected.
Working with Bruno in Cabot, AR.
Seems to be pretty good.
Thanks
   / XR4150 no throttle, failure codes, difficulty w / LS support #6
What part of Texas are you located?
I'm not...anymore. I was in Galveston county. Now living in Arkansas.
   / XR4150 no throttle, failure codes, difficulty w / LS support #8
NP .. I was going to refer you to a great LS dealer with shops in Austin (Spicewood) and Greenville. They won't screw you around.
Sorry your having issues. My XR4155HC is even better than my previous XR4046HC.
BTW .. welcome to TBN!
Thanks, Rick.
Actually, you affirmed my choice of selling dealer. The crew at RCO is the best.
Long story. Had an XJ2025H. Loved it. Harvey flood, lost house and submerged tractor. Tractor sat at RCO Bee Cave 6 months while arguing with insurance. In the interim, house was total loss (lost fight with FEMA and insurance). Moved to AR Dec 2017, settled with tractor insurance march 2018. Upgraded through RCO to XR4150H April 2018. It's been a great tractor. 1st trouble I've had. Looks like Bruno may be good. We shall see.
Thanks
Dee
   / XR4150 no throttle, failure codes, difficulty w / LS support #10
Thanks, Rick.
Thanks
Dee
John Ryan is a great Dealer and represents LS well. I now consider John and Alex friends.
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
