Backhoe XR4046H factory Backhoe
   / XR4046H factory Backhoe #1
Woodshaver
Upstate NY
Ford, XR4046H
With my old Ford 801 backhoe was able to "pull" the tractor when it was stuck or to move it when digging.
Sure many of you have done this with a backhoe, the new back hoe on the 4046H does not seem to have much pulling power for the tractor. Had the brakes off, loader bucket up, stablizers up. Did not try with Hydro shifter in neutral, could this be the reason or just not enough pull with this back hoe for the tractor size?
   / XR4046H factory Backhoe #2
If the hydro is in gear (L,M,H) it will be hard to move the tractor. If in neutral, the BH should easily pull the tractor. I don't have the factory BH but have an old Woods BH750 w/sub frame I fitted on my XR3037HC and it does the same thing.
If the hydro is in gear the tractor doesn't move (unless you are on a steep grade) but in neutral it will free wheel.
Thanks,
Not use to having a hydro transmission so makes sense to have the gear shift in neutral just as with a gear tractor.
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
