XR3037 Workshop Manuel
/ XR3037 Workshop Manuel #1
bytwnracer
Branson
Looking for a workshop manual. No dealer close by to go ask for one.
I have a 2018 XR3037 cab model. It is not starting and I got the issue down to the fuel shut off solenoid not getting power. When i unplug the connector on the solenoid and give it power I can hear it click and the tractor will start but it goes to full throttle max rpms. Tractor will turn off when I disconnect power to solenoid so solenoid is working as it should.
Is there a fuse or relay that would prevent fuel shut off solenoid from getting power when I turn the key? If so where is that fuse or relay located? Or possibly a bad ignition switch?
Why would tractor go into full throttle when I do start it with zero response from foot or hand throttle control?
Lastly I get two codes on dash but neither seem to have anything to do with my problem AB07 and AB11.
Thanks for any input!
