Walter L
- Joined
- Nov 19, 2006
- Messages
- 354
- Location
- Delhi LA
- Tractor
- LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
While greasing my FEL for the first time i had one zert fitting that i could not lock my grease gun onto (it a 10mm zert) tried to remove the zert to replace it but the 10 mm socket cant grab the zert so i decided to check the other zerts same problem so i will have to knock the head off any zerts that i have problems with and use a reverse drill to remove once the Warenty runs out. The Dealer had no problem getting me a new pin w/zert but a little disapointed in LS design of the pins and not being able to remove & chang bad zerts with a 10mm socket. I was wondering if all are like my pins?
