X729 or X749
   / X729 or X749 #51
rubadub said:
You won't hear the diesel guys talk to much about the glow plugs, fuel gelling and the different additives.
I thought I'd repeat, once you go Diesel you'll never go back. I live in Minnesota and have added Power Service to one of my two Diesel cars once just as a preventative on a -40 morning. The fuel tank on my tractor is located right next to the back of the dash so it gets enough heat that I have never had to add any additive for winter use. I do keep it in my unheated garage and do plug it in but that's not because it won't start but because I like the engine warmed a bit just for my peace of mind.
   / X729 or X749 #52
Fuel prices in Traverse City today.
Gasoline $3.90 a gallon
Diesel $4.26 a gallon
Were 36 cents a gallon to start then add the different additives for the diesel, plus if you need a block heater, and keeping track of the summer and winter blends and when you can get it.
Then how long will it stay in your tank or can without gelling, then the higher cost to buy the diesel motor up front plus if you need it fixed you better hope you can find a good diesel mechanic that will work on it and that won't be cheap.
I know Auto Zone sells the diesel additives by the pallet loads, and it isn't cheap.
So their :D
Rob
Got to disagree with you on this one.I also live in michigan(55 years)I have a diesel tractor,Kubota RTV 900,JD 740,just sold my dodge diesel truck.NEVER had any gelling problems of any kind.I buy diesel additives for around $10-20 that will protect $350 gallons of diesel fuel from any gelling problems.My equipment stays in a unheated pole barn.I have a 1996 ingersoll 4020 with a gas 20hp onan motor that gobbles fuel like nobodys business on the other hand my JD 740 sips diesel fuel.coobie
   / X729 or X749 #53
I have a 2011 X729 with a heated ROPS soft side. They are are tight on cold and windy nights. Two minor complaints with it. One is the vynil filler\panel between the hood and windsheild has a poor fit and limits visability some what. I made an acrylic panel retained with velcro. The other is I wanted a side window to open, so I bought a used set of hard side doors. I also remove the cab for the summer. Takes less than a half hour. Keep in mind it's about $1000.00 more for a hardside when new, and $3400.00 to convert a soft to hardside with new parts later.
The curtis heater has a fan like you would find in a PC. It only draws .75 amps on low speed and 1.9 amps on high. The wiper will draw 3.7 amps max. I mounted halogen worklights on my cab that draw 8.5 amps, so I installed the alternator upgrade.
Snow blowing is great. No additional weight, other than the cab. I do a large area and a good part of my back yard (yes, I snow blow the grass) in 35 minutes. We had a very wet slushy snow fall last year and I was concerned the blower would not handle it, so i brought my plow truck home. Silly me, the X took care of the slush no problem.
For mowing I have a 54c deck. The X holds the hillside like a mountain goat. I have a MC519 with power flow and I go up and down a steep hill to my dump site with no problem at all. For fun when I come up the hill I stand on the forward pedal and it rips up the hill.
I have a 45 loader. I am very carefull when turning. Works great.
Gas vs Deisel- I have more power than I need. I went to the deisel first thinking that it had more torque. But after comparing the specs it only has two or three more pounds of torque. Higher resale value yes, better fuel economy yes, longer lasting yes. One thing I dislike about the gas engine is that when it's cold it needs alot of fuel to start and run properly, so in the winter it stinks for the first few minutes untill it warms up. I would prefer the smell of burnt deisel over burnt gas any day.
You cant go wrong with either machine.
If you need any pics of anything let me know.
   / X729 or X749
Do you also remove the front windshield of the cab in the summer? I want to be able to remover the entire cab in summer to allow me to mower under the trees, etc.
   / X729 or X749 #55
1*I just don't see a benefit in upgrading to a subcompact.
2*I realize the price is about the same.
3*I think the X700 series will be better for mowing and blowing snow than a subcompact.
I would love to hear everyones' thoughts on this too.
1*When you can be get more tractor for the same or less money it makes perfect sense.
2*I bought a new subcompact for several thousand dollars less than a JDx749 garden tractor.
3*No it wouldn't I've had 3 garden tractors and replaced all 3 of them .
I now have 3 Sub Compacts.
No way would I ever want to get back on the garden tractor treadmill. :(
   / X729 or X749 #56
I remove the whole cab. When I wired the cab I made one connection to the starter to supply my aux fuse panel. I also installed dry breaks so I do not have to drain and fill the cooling system each time. Pull the doors, 12 bolts and its off. I leave the two lower bolts in the rear and use them as a pivot point to lower the cab on dolly. Not having glass windows on the back saves some time as I just pull off the side\rear plastic window.
Here's some pics.
   / X729 or X749 #57
Lbrown is right, dollar for dollar, however I would never attempt to mow my slopes with a Scut. Higher CG would scare me.
   / X729 or X749 #58
LBrown just doesn't like the x700 series Deere and instead has to have three Kubota subcompacts instead. His setup has some advantages if your slopes aren't to steep and you have a separate garage to store them all in. For me I only want to have one machine this size to do everything I need to do.
   / X729 or X749 #59
Diesel all the way. Of course, you could also step up to something a little more substantial for the $$, like the 1026R.
The 749 is pricey and for the money I think a subcompact makes more sense.
When i realizedi could get away from garden tractors into real tractors for less money i made the switch over and haven't looked back since.;)
   / X729 or X749 #60
Buy a diesel because you want a diesel. Don't buy one just for fuel economy because you'll be 30+ years breaking even vs. the gasser when the initial cost difference is figured in. Both the diesel and the gasser will last for many many years.
One should easily get way more than 1000 hours out of a gasser. I have a 425 AWS. Original owner. Now at 1035 hours and still running strong. Plenty of power. My next one will be an X749.... just because I want to go diesel (no real well founded reason). I am tired of putting on chains every fall. That's hardly reason enough to spend all that money for an X749. But, I salivate everytime I go to the dealer for that shiny new AWD/AWS beauty!
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2002 EZ-GO Shuttle 2x2 E Electric Golf Cart (A50860)
2002 EZ-GO Shuttle...
2018 Hyundai Elantra Sedan (A48082)
2018 Hyundai...
2015 Jeep Cherokee SUV (A48082)
2015 Jeep Cherokee...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
