X729 or X749
/ X729 or X749 #21
jkadylak
Don't let yourself be talked out of the diesel by rubadub. They do last a lot longer and their retail value remains higher. Just sayin'
No doubt he likes his non-diesel and has good reasons for stickin up for his choice. Don't we all. :)
/ X729 or X749 #22
Diesel all the way. Of course, you could also step up to something a little more substantial for the $$, like the 1026R. The 749 is pricey and for the money I think a subcompact makes more sense.
/ X729 or X749
I just don't see a benefit in upgrading to a subcompact. I realize the price is about the same, but I think the X700 series will be better for mowing and blowing snow than a subcompact. I would love to hear everyones' thoughts on this too.
/ X729 or X749 #24
rubadub said:
What is a hydro heater and what runs it?
Rob
It is like an engine block heater but is screwed into the back of the hydrostatic transmission near the PTO (Deere 4100). It has a cord that unplugs right at the heater so it isn't in the way. It was cheap and heats the oil similarly to the way an engine block heater heats coolant. I plug it into the 110v outlet on my garage wall next to where I plug in the engine block heater.
/ X729 or X749 #25
I prefer the x749 over the subcompact for a few reasons. The all wheel steer will turn alot sharper without damaging the turf. The single speed hydrostatic is setup with optimum gearing to handle everything you wan't to do. No need to try to figure out whether you should be in low (too slow) or high (too fast). The x749 has the same 26 12 12 size tires and almost the same hp. One of my concerns that sealed the choice was the low squatty design of the 749, working in the mountains on steep slopes it has performed flawlessly.
With a 1026R you do gain position control and the ability to add a small fel. You have a higher lift capacity on the 3PH, two ranges which should be better for fel work and a few other extras. It is more like a tiny utility tractor is the best description I can think of. It would be a good choice for the guy who wants to add a small backhoe and /or who wants to have a fel for moving small amounts of dirt and gravel. In open areas that are closer to level it would be more versatile, you can get alot of nice attachments such as the quick connect deck.
When I built the landplane grader a couple of weeks ago I was concerned that it may weigh too much for the 749 to lift but the following Monday we tried it with one of my helpers (175lbs) standing on it and it lifted him up just fine no bouncing. At any rate the 3PH on this mower works extremely well and should be no problem for 5' subcompact implements. To the point in most conditions I don't see where the 1026R is going to perform much better with the majority of implements you would need. I do see the x749 being alot better at mowing around obstacles and climbing and turning up hillsides. The all wheel steer not only allows you to steer tighter turns but also provides more steerage too, so less problems with front mounted blades and snowblowers.
/ X729 or X749 #26
jkadylak
Well been there I guess a little bit about who I am and why I'm praising the x728 is in order, so here you go.
If we take a look back at what I just posted it was a ton of information with pictures and a video and a spec sheet, quite a bit of information that I didn't see from the diesels guys other then buy a diesel.
I was born in Michigans Northern lower pennisula and worked at lower paying jobs up until around 40 something years old. My wife was a stay at home mom with our four children, so I learned how to fix things and through out my 70 years of fixing things got an appreciation for things that were well built and worked good and didn't need a lot of repair.
I was a real Tool and Die Maker and also worked with a welder for a couple of years welding and fabricating.
I also self taught myself to fix cars, trucks and motorcycles and put my self up a nice shop.
I took every cent I could save and bought tools one at a time and also learned how to do body work and paint plus all the carpenter work to build my garages and remodel my house and what ever else needed to be built.
I worked full time jobs my whole life plus extra jobs, where ever I could turn a buck I would be after it.
Sooooo in that time span I learned to appreciate two stroke engines that could turn 12000 rpm, muscle cars with big displacement stroker motors and anything that had 2 or four wheels it peaked my interest.
In my later years 55 plus I did a bit of fabricating and painting and thats when I started looking a little closer at the John Deere garden tractors.
My x728 in particular I would get under it and look it all over and admire the workmanship of how it all went together and the paint and metal work, they truly are a really well made tractor.
The first time we used it was in the winter blowing snow and with the cab heater and power steering I was a bit put back, I didn't have any idea it would do what it did with such little effort on the operator, like a limo on the freeway, no chains and the fourwheel drive, simply amazing, yes they are that good.
Now as for the diesel and gasoline engine, two different animals, the diesel has been been around for years, but not the electronic fuel injection on the Kawaski Twin, this is engineering at its best, they start fast and run clean.
We are really lucky to just be able to buy a machine that runs like they do, I'm 70 years old and feel very fortunate just to be able to get one, John Deere should be very proud of the X728 and how it runs and what it does.
One last thing, take the information I just put out and read it again, because it is very informative if you really think about it.
Rob
/ X729 or X749 #27
In my opnion only, I would go with the Yanmar Diesel in the X749 AWS, a lot more fuel efficant then the gas engines. The X728, gas mower is a very nice mower as well, but I would NEVER go back to a gas mower again. I had a 425AWS with the Kawaski gas engine at one time, in fact for only a few months, while the tractor its self was great, that Kawaski gas engine was a pig on fuel, especially when running the 60" deck, just from my experence only.
Now the X728, has more power then the 425 did, and more horsepower, but for whats it worh, I would go Diesel in a heart beat. Those Yanmar Diesels just sip the fuel compared to a gas engine. I am not saying that the X728 is a bad mower, but I prefer the Diesel engine over all.
Jason B
/ X729 or X749 #28
Currently, my main tractors in my lawn maintence business is a Deere X744 AWS & a 2006 John Deere 2305 subcompact.
Both my X744 & 2305 have the same Yanmar Diesel engine rated at the same hp. I love the MFWD on my 2305 for blowing snow, and like the fact that for road travel, I can put it out of 4WD when not needed, unlike the X749 that is always in 4WD. I agree that 4X4 is a must have, but there are some jobs out their that don't require 4X4, such as mowing flat areas or pulling a small utlity cart. Actually wish Deere would offer the option of turning off and on the 4WD on the X700 series, like they once offered on the X595.
Now, my X744 AWS will cut a lot closer around objects then the 2305, and is much more stable on slopes then my 2305, even though the 2305 has ROPS and the X744 doesn't, the X744 seems more stable.
I mainly use the 2305 for snow removal now, as I just put a Curtis soft side cab on, this past winter, and removing it on and off has become too much of a pain, on top of that the cab rubs against a lot of tree branches.
Certainly, a subcompact has a lot of benifits, especially if want to put a loader on. You can't get a loader for a X749AWS, only the 2wd versions: X728, X720, X748.
If you need a loader, then its best to move up to a subcompact, but its hard to beat the AWS for manuverablity. I doubt I would buy another Garden tractor without AWS, seeing as they are so manuverable compared to a 2wd garden tractor, just my two cents though.
Jason B
/ X729 or X749 #29
Fuel prices in Traverse City today.
Gasoline $3.90 a gallon
Diesel $4.26 a gallon
Were 36 cents a gallon to start then add the different additives for the diesel, plus if you need a block heater, and keeping track of the summer and winter blends and when you can get it.
Then how long will it stay in your tank or can without gelling, then the higher cost to buy the diesel motor up front plus if you need it fixed you better hope you can find a good diesel mechanic that will work on it and that won't be cheap.
I know Auto Zone sells the diesel additives by the pallet loads, and it isn't cheap.
So their :D
Rob
/ X729 or X749 #30
...............Were 36 cents a gallon to start then add the different additives for the diesel, plus if you need a block heater, and keeping track of the summer and winter blends and when you can get it.
Rob
Sorry Rob. Don't buy it for a second.
Wisconsin winters and I've yet to add anything to the diesel fuel, nor plugged in a heater.
Buy from the local pump and the summer winter fuel is taken care of there. About 10-15 cents difference on price.
But it is really ok for you to have what you want, and enjoy it for all those good reasons. :)
/ X729 or X749 #31
No doubt our original poster knows what he is doing by asking the questions first before he buys one, thats the intelligent way to do it.
I didn't do a lot of research before I bought the x728, but as it turns out I got lucky, but I know I wouldn't have bought a diesel.
I have bird and squirrel and humming bird feeders, and having a diesel in the vicinity wouldn't work out, especially warming one up, the part where the tractor shakes and then you clean her out:D
/ X729 or X749 #32
I should add that diesel stores much better than gasoline/ethanol blends do today.
/ X729 or X749 #33
My brother mows 4 acres on a tank with his x485. I mowed 7 acres on a tank with my X744. I traded it for a x748 this year, but it should do about the same. All without killing one animal. JC
/ X729 or X749 #34
I am currenlty looking at purchasing a X729 or a X749. I will primarily be using this garden tractor for mowing and blowing snow, so I don't see any need to go with a 2305. I have appoximately 5 acres of land and will be mowing about 1 acre of it. There are a lot of trees, hills and obstacles so I know I want the AWS. Also, the driveway is a little over 500 feet long with a lot of bends & turns and a steep hill. Could anyone tell me if the diesel is worth the extra money? I am mostly concerned about blowing snow. I live in Niorthern Michigan and we get a lot of snow. Does the torque offered by the diesel engine make a big difference? Also, does the diesel have a much better resale value when compared to the gas engine. The gas engine is rated at a higher horsepower (27 hp for the gas vs 24 hp for the diesel) and the gas engine is $1000 less than the diesel engine. Any input or experience with these would be greatly appreciated.
Hey neighbor, I'm a little north of you on Elk Lake. I have the X749 at my place in Grand Rapids and a 455 AWS here at the lake. I have owned the gas versions also so I speak from experience; the diesel will out perform the gas in any situation and there is very little smell. Go for the diesel and you will be happy.
Where are you shopping? Classic or Work and Play?
/ X729 or X749
I went to classic, but then called work and play as well as Voelker implement. Voelker quoted the best price so I think I will order it from them. What do you use the 749 for? Clearing snow with a blower? If so, what do you think? I have some friends telling me it will take a long time to snowblow the driveway.
/ X729 or X749 #36
1* The gas engine is rated at a higher horsepower (27 hp for the gas vs 24 hp for the diesel) and the gas engine is $1000 less than the diesel engine. Any input or experience with these would be greatly appreciated.
The X749 Diesal will work circles around the Gas X729.
/ X729 or X749 #37
I've been using an x748 for three years and it is hands down the best lawn mower I've ever had. (I'm going larger this month with a Kubota L3940 because I wanted more utility, not because the x748 wasn't a good machine)
I mow 6 acres on 2.5 gallons of diesel. Trust me, you'll only small diesel when you fill the tank, and it runs so smooth. It's also quieter than the gas mowers.
They are fantastic machines, go with the diesel. You won't regret it.
/ X729 or X749
Jason B
I was told you could add the FEL to the AWS models, however, JD does not recommend it because if it is loaded and in the up position, it would be tipsy if your turn the wheel sharply. Either way, I am sure the capabilities of the FEL are limited on this model in comparison the that of a SCUT, especially for the additional $4k that I was quoted.
/ X729 or X749 #39
Question jkadylak, how long will you keep the diesel or how many hours will you put on it before you maybe upgrade or will you keep it and never sell or trade it.
It might be worth the time to take a ride to a couple of dealers and do a cold engine start on one of these yanmars with 1500 or so hours.
The Kawasaki and yanmar should both be running good with that many hours, but I'll bet a shiny new dime that diesel will shake rattle and roll and you will need to clean that lil smoke bomb out, where that injected kaw will fire up instantly and idle smooth.
You won't hear the diesel guys talk to much about the glow plugs, fuel gelling and the different additives.
Rob
/ X729 or X749 #40
I blow a u-shaped drive total length about 325-350', the grade is 10% on the one side. The X749 is amazing, I don't use chains ( I do use 6 suitcase weights) and have great traction up and down the drive. My yard is very hilly and again the traction is the best of any tractor by far, especially when wet.
I use a lawn service at the cottage because I can't get up there on a regular basis, the X749 will cut the lawn almost as fast as the zero turns and there is less turf damage.
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2022 EZ-GO ELITE...
2007 Ford Explorer Crew Cab Pickup Truck (A64556)
2007 Ford Explorer...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2022 EZ-GO ELITE...
