X728 hydraulic problem
/ X728 hydraulic problem #11
Beenthere
Thank you very much for your help and you called it right. I had the hoses hooked up to the right color connector but they were the wrong two hoses.
I only use the lift on the quick hitch when using the snowblower. I connected the green and gray hoses when I should have connected the green and black. I was connecting the hoses in pairs instead of all four at the same time and I was using the wrong pairs.
DOH! It sucks getting old.
OH yeah, that color coding make a lot of sense, NOT.
Make a drawing, will never happen again.
Richard
Richard
Richard
What bothers me is that I was absolutely certain that the hoses were hooked up correctly!
I've done this so many times in the past that I just hooked up the two hoses from memory with absolute certainty that these were the two hoses that I have always hooked up in the past. It wasn't a case of forgetting something, it was more a case of having a false memory. I was certain that it was hooked up right until it occurred to me to trace the two hoses back to the hydraulic cylinder.
The next time I will trace the two hoses from the cylinder back to the connections on the tractor.
Mike.
2015 MACK GRANITE GU713 T/A DUMP TRUCK (A59823)
2015 MACK GRANITE...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
