X724/744 and attachments
   / X724/744 and attachments #1
FuntoMow
Connecticut
John Deere X300
Thoughts or opinions on the x724? Does the AWS limit attachments? I have read conflicting reviews. Can any owners or knowledgeable
John Deere people share their experience/knowledge.
   / X724/744 and attachments #2
I've sifted through this a bit and about the biggest DNF is the 7 iron deck. Guys are blowing snow and roto tilling with 4ws models. We demo'd a 724 and while the 4ws was nice it was just a bit too goofy for us.
If you get to do a demo I'd be curious to hear how the diesel vs gas hydro response/acceleration/speed is.
   / X724/744 and attachments #3
I have a wide assortment of attachments for my x749 and it works well with them. With AWS you can not use the 7 iron deck or a fel, seems to be fine with everything else.
   / X724/744 and attachments #4
You can use the FEL but Deere doesn't want you too, they are top heavy and are unstable, but it can be done.
   / X724/744 and attachments #5
Two details to note, there is an interference on the frame for the rear support of the 45 FEL ((left side). The hydraulic pump is 4.5 gpm where as most of the X Series is 6.0.
   / X724/744 and attachments #6
It's a minor interference with the rear steer bracket that has an easy fix.
   / X724/744 and attachments #7
Tommy, Your setup was my inspiration.
Did you modify the bracket and eliminate one of the bolts?
Did you add any shims?
   / X724/744 and attachments #8
I modified the bracket, but did not have to modify the 4WS idler arm bracket. I shimmed the hydro to 1250 psi. Works great.
   / X724/744 and attachments #9
Again, inspired, your modifications look better. Ordered shims and gauge today. Picked up six weights yesterday. Just call me Tommy Jr.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
20702 (A51694)
20702 (A51694)
