X720SE starting issue
/ X720SE starting issue #1
250exc
Rome,Pa.
John Deere X720SE
"POPS" or backfires through the intake on first start of the day sporadically, any ambient temp., 570 hrs., valves have been adjusted 3x's, 91 octane ethanol free gas, spark plugs replaced every 200 hours, air filter clean, fuel filter been replaced. Just curious if anyone has experienced this concern with there Kawasaki FD750D EFI engine?
Thanks
/ X720SE starting issue #2
Don't know about the EFI engine, but typically when the engine backfires thru the intake, it means that the fuel mixture is lean.
This thought also is reinforced by your comment that it only happens when the engine is cold.
Richard
/ X720SE starting issue #3
Have you check the intake manifold bolts for proper torq?
I agree on the lean and yes I have checked the intake bolts for torq. I even sprayed carb cleaner to see if it would suck in while spraying around the intake. Tonight I checked the air sensor, cylinder temp sensor and the pressure sensor. All are operating within parameters according to temp. and/or pressure/vac. Maybe I am using the wrong starting procedure, any suggestions??????
/ X720SE starting issue #5
Turn key on and wait for the pump to stop pumping, then switch to "start".. If you wait for pump, should be correct procedure.
I have cycled the key to allow fuel pump to run, tried no throttle, half throttle, 3/4 throttle, still does it. The other night I checked the resistance of the air sensor, cyl. temp sensor and the pressure sensor. All are operating w/in parameters according to temp., pressure and/or vac. My next step is to clean and apply di-electric grease to all harness connectors, grounds etc.
Tonight I checked the fuel pressure = 25PSI = OK. Will see how it starts in the AM.
Started OK this AM @ 3/4 throttle. Last night while I was checking fuel pressure, I removed the fuel pressure regulator and blew through it with compressed air!!!!!!!!!!
/ X720SE starting issue #9
Have you added seafoam or injector cleaner since this is EFI? It might take a couple of tanks for it to do the cleaning. If it then continues, ask the dealer if there is a way to check the control unit (computer test port to see what the software/firmware are doing)
/ X720SE starting issue #10
By chance, did you run out of fuel and have this problem after that?
There is a procedure to follow if you do run out of fuel.
Never ran out of fuel and yes I did add Lucas fuel injector cleaner this AM before I mowed for 2 hrs.
I have now started the tractor 3x's cold, 3/4 throttle, cycle key to activate fuel pump, no pop. Hoping this trend continues.
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
