X595 Running HOT!!
/ X595 Running HOT!! #1
RWEST
Windber, PA
ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
Anyone else having a problem with their X595 running hot? Mine is used strictly for mowing (54C deck), it's coming up on 3 years old, and has roughly 200 hours on it. It seems to be getting worse - if the ambient temp is 80 degrees or above, that needle sneaks over very close to the red range after only about 1 hr. :eek:
I keep all the screens, including the one that has the little springy-clamp thingies on it, cleaned religiously, make sure the coolant level is at the proper level before I start, etc..., but, it seems to be getting worse.
You don't think they'd do something goofy like have the fan mounted backwards or something, do you? Hmmmm. :confused:
/ X595 Running HOT!! #2
Wash out your radiator with water. Also, make sure your screen is free of debris.
/ X595 Running HOT!! #3
Have you pulled out the oil cooler and cleaned between it and the radiator? Did you change the coolant after two years? I just bought a x495 that is a 03 model with 120 hours on it. Mine was not running hot, but the radiator was clogged with grass clippings. JC
/ X595 Running HOT!! #4
Check to make sure the radiator itself does not have debris wedged in between the fins. You might not be able to see it unless you look closely.
/ X595 Running HOT!! #5
Make sure the coolant concentration is right. Don't want any more than 50% and a little less is better as far as heat-rejection goes. Water is a better heat-transfer medium than glycol. I think you can go as low as 30% or so without corrosion problems.
/ X595 Running HOT!! #6
I used compressed air to clean the radiator -- blow from engine side back out thru the radiator. You have to do this in addition to cleaning the screen. Deere issued a bulletin to all X-Series owners on this topic around 2003 or 2004. If your engine still overheats then the thermostat may need to be replaced.
Thanks, guys.
I'll get in there and have a look at the radiator.
Hmmm. Where's the "I'm a dork" smiley button? :( Hosed out the radiator last nite - a bunch of gunk came out. Haven't had a chance to mow since then (t'storms came to visit), but, I hope to on the morrow, and we'll see how she does.
BTW - that radiator location's NOT one of J-D's best ideas. It's a real pain getting in there with a hose to clean things out.
/ X595 Running HOT!! #9
Sure sounds like you got the problem solved! I'm pretty **** about using the air hose to clean things and check over the tractor with. It's easier than water and helps me keep ahead of things breakin'! (Well... mostly.)
Don't ya just wish that you had 3-4 of those engineers when something is just a royal PITA to fix and it's mostly because of the way it's designed!?! You gotta be a dwarf, contortinist with skinny fingers to get at some of the things they engineered!
AKfish
Yes, I would love to watch THEM do it a few times. :D I imagine there'd be a re-design pretty quick. ;)
Reminds me of changing the oil filter on the last couple Ford Expeditions I've had - you can SEE it up there plain as day, but by the time you get it out of there, your arm looks like you've been in a fight with a wildcat or something.
BTW - I still haven't had a chance to see if that's solved the problem. It's started raining every day, right about the time I get home from work. At this rate, the grass will be a foot high when I do get to it.
Okay, it's official. I'm a dork!! :( After we cleaned all the crud out of the radiator fins, it's back to running comfortably in the cool range of the temp gauge.
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
Case IH 5100 (A64119)
X (A68191)
X (A68191)
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
