X530/X540 Qustions
   / X530/X540 Qustions #61
Will provide pics as soon as i get it. I also had the dealer install the mulching kit with blades. I'm not getting a bagger any time soon. I'm wondering how good is the kit in general? Should i have just stayed with the regular blades and side discharging?
I have used mulching mowers and loved them. But here in Florida, the soil is sandy and it takes the edge off the blades very quickly. I have been using the side discharge with a mowing pattern that leaves almost nothing left in the way of clippings. For my situation, the side discharge is fine. I think you will like the mulcher in the fall. I hear they do a number on all the leaves. Makes fall cleanup a breeze.
Another thing you are going to want to add is a good cart. These X540's have no trouble hauling a cart no matter how overloaded it is! The transmission can handle quite a bit. Not one word of any problems with the K72 trans.
I think you are going to love your new toy.... I mean tool. My whole neighborhood is loving all the work I am getting done with mine...
   / X530/X540 Qustions #62
Thanks guys. Maybe i'll try the side discharge first. I've been paying to have the grass cut the last few weeks and i don't really see the clippings.
@Eric, I'm going to get a cart/buckets for sure. Probably getting the snow blade/blower for the winter. I used to live in Florida as well, Coral Springs. Lucky you, get to use ya toy....i mean tool all year long. lol
   / X530/X540 Qustions #63
I just got an x720 with the mulching kit and although I have only used about 4 times, I think it works great. No signs of grass clippings and it chews up leaves like they didn't exist. I also have sandy soil that ate the blades on my old snapper so I checked the blades after mowing the 4th time and found them to be still like new. The JD mulching blades that come with the kit seem to do a good job. By the way, JD wanted almost a $100 to install the kit. If you are capable of changing the blades, installing the kit is no more than 4 wing nuts and a clip. Super easy.
   / X530/X540 Qustions #64
Yeah when i got the total with the mulch kit installed I canceled that from the order quick. I can do this myself for sure. I've been reading great things about the Gator mulching blades. Maybe I'll try those out as well. Any of you guys using Gator blades?
   / X530/X540 Qustions #65
Just got the x540 this morning. I cleaned it up as it was dirty from the dealer. I didn't mind cleaning it, as I did a fine inspection of the tractor. As you see by the pictures it only has .2 hours, but came delivered with .1 hours.
The deck has about 3" of paint scrapped off the side bottom lip. The dealer is sending me paint.
The deck rollers show some slight wear. The dealer said its from the gravel in the yard when they took it out. Not sure if i should be that **** and ask for new rollers.
The seat was dirty and I couldn't get it out even with degreaser, and i found a few small cuts as well, so the dealer is ordering a new seat as well. Going to buy a seat as well.
Other than that this thing looks awesome. Going to ride tomorrow morning.
   / X530/X540 Qustions #66
Looks good! :) You will enjoy it for decades to come. On my X500 the dealer said it was important to change the oil at 8 hours. Don't know if true for X540 since different engine but something you may want to check.
   / X530/X540 Qustions #67
Same thing on the x540. Thanks again.
   / X530/X540 Qustions #68
The 8 hour oil change is important. Just did mine on a x720 and the oil was chocolate in color. It is easy to do but then you have to wait for 42 for the maintenance task.
Looks good!! I have no doubt you will enjoy it. I put another 4 hours on my 530 this weekend and have reached the 8 hour oil change. My wife is picking up an oil change kit from the dealer today and I will be taking care of that this evening.
   / X530/X540 Qustions #70
Does anyone know if they make a seat cover for the 21" seat on the x540. I have been searching online, and can't find it.
2023 UNVERFERTH 632 LOT IDENTIFIER 165 (A53084)
2023 UNVERFERTH...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
