X485 Voltage Outpur
   / X485 Voltage Outpur #1
walleye
cedar rapids, ia
JD X485
Under full Throttle, what is the voltage i should see measuring across the battery?
   / X485 Voltage Outpur #2
After start up I would expect 14.5 volts or so then slowly go down to 12.5 or so.:welcome:
   / X485 Voltage Outpur #3
What Murph is describing is the function of the voltage regulator in response to the battery. If the battery or regulator is failing, you may not see those readings.
Does the x485 actually have an external brake solenoid switch? I see a solenoid switch on the right side that appears to bee part of forward and reverse pedals, but don't see one that is part of safety start switch. i am having trouble when hitting the key and starter not engaging. the brake linkage appears to be a little sloppy. any thoughts out there?
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
2020 Bobcat T595 Compact Track Loader Skid Steer (A51691)
2020 Bobcat T595...
78'' skeleton /rock bucket (A53421)
78'' skeleton...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
