X485 Service Manual
   / X485 Service Manual #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
Any one have an electric copy of the service manual for a X485 they would be willing to share?
   / X485 Service Manual #2
I've got the printed version, Tech Manual TM2023, X465,475,575, and 585, that I'll sell for $25 plus shipping. Got it along with my X475 way back when; unit didn't run well when cold soaked below 5 degrees and Deere couldn't figure it out, so I didn't have it long. I attached a pic. An option if you don't find the electronic version.
   / X485 Service Manual #3
What electrical do you need info on??
   / X485 Service Manual #5
You are right, I miss read the first post and thought he wanted electrical diagrams :eek:
Don't really need it right now just would like to have it just in case. Only has 370hrs but I just changes the trans oil since it was probably original.
   / X485 Service Manual #7
Does the service manual have anything on adjustments to the forward and reverse pedals on the x485. Sometimes when I hold the brake pedal all the way down to start the engine, it feels like it is in gear, a vibration in the brake pedal. And are you still willing to sell the manual?
   / X485 Service Manual #8
Though a manual is a great thing to have, you may learn what you need to know from pulling the deck and inspecting the driveline. Does it want to lunge or is it the vibration really you are after? Roll the idler pulleys around to inspect for flat spots on them and the belt as well. A stick in the transaxle cooling fan will raise all kind of heck.
   / X485 Service Manual #9
No transaxle cooling fan on the X485 ;)
But doing what tomplum suggests with the deck off, the forward / reverse pedals and the brake pedal may show something out of adjustment.
   / X485 Service Manual #10
Do you know how to make adjustments to the pedals?
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
3 pt Aer-Way (A50514)
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
