X370 Foot Pedal to Hand Control Conversion
   / X370 Foot Pedal to Hand Control Conversion #1
Jg1
Cub Cadet 7195
I have a 2022 X370 and I was hoping to convert the forward/reverse foot pedal control to a hand control. I’ve read some articles but my linkage seems to be a little different. I haven’t made anything up yet but the few times I’ve had an idea for mounting a rod or lever on my pedal, the break pedal looks like it would be in the way. Right now I’m using a cane to push the pedals in but I can’t use the cruise control when I’m snow blowing. I would appreciate any ideas or if someone has done this already if they could send some pictures.
Thanks
   / X370 Foot Pedal to Hand Control Conversion #2
It would take some engineering. My first thought would require modification of the fender deck. But, the pedals easily remove and levers could be fashioned that bolt on. If you went through the existing holes on the fender deck, I'd think the brake pedal would also need modification.
   / X370 Foot Pedal to Hand Control Conversion #3
Where do you want the hand control located. Some older tractors like 316, 317, 318 had the HST in the dash on the right side and I always found that to be an awkward position.
Like Tom stated,
You will need to do a little engineering on getting the hand lever in a position that works without interfering with where your foot normally rests or any other control like brakes, etc.
   / X370 Foot Pedal to Hand Control Conversion #4
Jg1
Show a pic or two of the present situation, and maybe some helpful ideas will come forth.
If me, I think I would start with the fender deck off, and attempt to find a way to tie into and move the linkage system leading up to the foot pedals.
Sure hope you find a way to adapt to getting beyond having to use a cane to operate your tractor for snow removal.
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
