X300 - only one cylinder working
   / X300 - only one cylinder working #1
PaulColbert
X300
Hello,
It's amazing to see how talented and creative these webcam girls can be in their shows.
   / X300 - only one cylinder working #2
Welcome to the forum!
What's an X300? :oops:
If it's gas, I suspect a plug wire is shorting out on the tin when in place.
   / X300 - only one cylinder working #3
Paul, You may wish to post this in the JD mower section. At least I'd guess whats the mower you have. Posting information is a good thing.
   / X300 - only one cylinder working #4
Don't really matter except your mouse renters chewed up either the spark plug wire or the trigger wires from the mag to the coil itself. Kind of surprised the motor didn't puke, mowing with the shroud off. The shroud directs cooling air over the cylinders. You need to get some mouse bait cubes or use scented dryer sheets.
Land Pride 3 pt 54" Box Blade (A50515)
Land Pride 3 pt...
2020 International MV607 2,000 Gallon Water Truck (A50323)
2020 International...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F450...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
