X300 - only one cylinder working
   / X300 - only one cylinder working #1
PaulColbert
X300
Hello,
It's amazing to see how talented and creative these webcam girls can be in their shows.
   / X300 - only one cylinder working #2
Welcome to the forum!
What's an X300? :oops:
If it's gas, I suspect a plug wire is shorting out on the tin when in place.
   / X300 - only one cylinder working #3
Paul, You may wish to post this in the JD mower section. At least I'd guess whats the mower you have. Posting information is a good thing.
   / X300 - only one cylinder working #4
Don't really matter except your mouse renters chewed up either the spark plug wire or the trigger wires from the mag to the coil itself. Kind of surprised the motor didn't puke, mowing with the shroud off. The shroud directs cooling air over the cylinders. You need to get some mouse bait cubes or use scented dryer sheets.
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2014 Fiat 500L Hatchback Sedan (A50324)
2014 Fiat 500L...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
