X300 Engine problem
/ X300 Engine problem #1
sandtuck
Mississippi
Kubota M7040 MFWD, FEL, Hydraulic Shuttle and John Deere x300 mower
I purchased a new X300 lawn tractor the last Saturday of April this year. I used it twice and in the middle of the second cutting, only 13 days after the purchase, it started running bad. I took it back to the dealer that day and they went to work on it immediately. They called me two hours later and said it was ready, that a push rod had come loose. They repaired it, tested it, and loaded back up for me. Today, with only 32 hours on it, it is running bad again and seems to have the exact same symptoms.
Unfortunately, it is after hours on a Saturday, so no help or satisfaction today and the grass needs cutting desperately. I guess I have to break out the old cheap MTD I bought from Walmart many years ago, while my expensive, financed, John Deere sits quietly buy. The MTD has never failed to crank... It is just worn from use.
Has anyone else experienced this problem with an X series tractor?
My big Kubota tractor has never given me a moments trouble and never lets me down. Hope. I didn't buy the wrong brand. What is the John Deere policy on something like this? I will always be Leary of this one. It is only 3 months old with serious engine trouble twice. A replacement seems in order to me, or give me my money back and
Let me try my luck with a Kubota, etc. This is NOT a dealer complaint. They treated me good last time and I can't fault them for not being open on Saturday afternoon.
I just don't want to keep taking it back and wondering every time I crank it if it will cut the grass without going belly up.
Frustrated!
Sent from my iPad using TractorByNet
/ X300 Engine problem #3
You should have a 4 year warranty, or 300 hours, what ever comes first.
Warranty is not the point. I don't want to continuously have to be dealing with problems
/ X300 Engine problem #6
I'd pressure the dealer to replace with X310. It's a newer model with more features. Don't know what the cost difference would be but maybe the dealer, as a gesture of goodwill, would be willing to cover all or part of the difference? If he's not willing to deal then just follow the warranty, in there some place is probably language related to lemon (or words to that effect) replacement.
After two major problems in the first three months, I don't think it would be unreasonable to expect a new engine or a replacement mower.
This is not a junker from Lowes, it is an X series from a JD dealer. I paid too much to have repetitive internal engine problems.
/ X300 Engine problem #8
That will be totally up to your selling dealer.
/ X300 Engine problem #9
Well, this is a bad reflection on Deere, and by relation, on the dealer. I'd think they would do whatever they can to stand behind their product. The X mowers are darn expensive, and I'd hope Deere steps up with good service.
/ X300 Engine problem #12
Who makes the engine for this model?
The engine is an air cooled Kawasaki twin with 17 HP. (X300) Should be a pretty good engine. If a push rod is repeatedly jumping off, then I would suspect a bad valve spring, or a valve guide problem. I would want to have the engine replaced with so few hours on the machine. How much more is the X320? It has 22HP, and the engine is larger in displacement.
/ X300 Engine problem #13
I have had really good luck with my Kaw engines, (2003 Bayou ATV and an older log splitter) so was looking at new lawn mowers with another Kaw engine. Hope this is resolved to your satisfaction.
/ X300 Engine problem #14
The X300 and X310 are basically the same tractor - the X310 has power steering and hydraulic lift added, which is why it has a different model number.
/ X300 Engine problem #16
The x310 also has the k58H transmission which is a step up over the k46.
/ X300 Engine problem #17
So, any resolution on this problem with the Kawasaki engine??
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2005 International 9200 Semi (A66285)
2005 International...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
IH 18' Cultivator (A66408)
IH 18' Cultivator...
