Would you work on this?
/ Would you work on this? #21
There is a reason it sat in the shed for 30 years. I had a couple that saw years of hard use. It did a great job for the time. BUT, the hardest to work on of any machine I ever had on the farm. So many bearings that will go out one at a time. That long serpentine belt was a nightmare and so hard to keep lined up.
Fix it up as a testament to your grandfather, but don't plan on using it much unless you need a reason to cuss. Oh, and please don't use it on a hillside. I don't want to even think about how I know....
/ Would you work on this? #22
Brothers farm came with some junk and in the back of the shed was a walk behind Yazoo mower and I brought it home replaced the belt and fuel lines that had rotted and serviced the motor…
Came back to life and did a great job… so good they wanted it back seeing what it could do :-(
Simple and well built with heavy plate for the deck.
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2013 Bush Hog 296 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2013 Bush Hog 296...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
Kubota GR2020G (A63688)
Kubota GR2020G...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
