3-Point Hitch Would you like to add 3rd Rear Remote to LS XR4XXX???
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #1
lostcreekranch
Elite Member
Austin County, Texas
NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
I have been discussing a factory provided / dealer installed 3rd remote, for my almost new LS XR4046HC, with my dealer John Ryan at RCO Tractor in Austin. He told me today that LS now has a part # for the kit but no parts to support the kit. I'm not sure if the new kit is for the XR4XXX only or maybe it will cover the XR3XXX tractors as well.
I use the two stock remotes for top and side link cylinders and want third to operate an angle cylinder on rear blade.
I know that a bunch of parts could be cobbled up to get a 3rd remote but, I would prefer it to look like it came from the factory.
The rear bracket for the 2 existing set of QD's has a 3rd set of holes for the 3rd pair of QD's. The right side console in cab has already got the slot for the 3rd control lever.
Is a 3rd remote of interest to any more of you out there? Perhaps if a number of us sound off on this LS might move a little faster.
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #2
Quote: Would you like to add 3rd Rear Remote to LS XR4XXX???
Yes. :)
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #3
I'd ke the third remote on my R4047. Doesn't seen to be a part# for that either, although I haven't called and asked the dealer yet.
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #4
Yep, I'd like to see a factory kit.
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #5
You would think that since they made a slot for it they would have a convenient way of putting a 3rd remote in there. I would like a third that is also a float.
Might be some progress on a 3rd remote kit at LS.
Hoping to hear from more XR owners wanting LS to get this done. If we get a bunch of responses we can us this thread to press LS.
Sent from my iPad using TractorByNet
Might be some progress on a 3rd remote kit at LS. <img src="http://www.tractorbynet.com/forums/files/ls-tractor-owning-operating/436371-would-you-like-add-3rd-image-3791264043-jpg"/> Hoping to hear from more XR owners wanting LS to get this done. If we get a bunch of responses we can us this thread to press LS. Sent from my iPad using TractorByNet
I guess pictures are still a problem.
The picture, I tried to upload, was a comparison of the piping between valves and the rear remote QD for two sets and three sets of remotes. Will try to upload again when the picture issue is corrected.
Trying again.
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #9
I currently have a customer that has an LS XU5065. He had the 3rd factory rear remote installed and we are still putting 3 more on the rear for a total of 6 at the rear and 1 more up front for a 3rd function. 9 sets (18) of remote outlets is quite a few couplers. :eek:
   / Would you like to add 3rd Rear Remote to LS XR4XXX??? #10
Any update on this as I would like to know if this can be done by the factory since I'm leaning towards a LS XR 41 or 3100
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55302)
2012 Ford F-150...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
Peterbilt (A51692)
Peterbilt (A51692)
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
