Would anyone be able to tell me the different levers in a Fiatagri tractor?
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #1
ektec
town
I'm new here so excuse me
If so please reply, I'm talking about the levers on the right side with the hitch, liftarms clutch brake etc.. I need to know which is which
Cheers.. I can PM you picture if you need photo
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #2
Try them and find out.:eek:
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #3
Which model?
I have a 100 90 DT I can speak to that.
Which model?
It's a 110 90dt... Im sure they are the same?
If you can help it would be great
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #5
G'day post or send me a pic of the levers you are talking about and we will see how we go
Jon
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #7
I was wondering if you received an answer to your question re the levers on the Fiatagri tractor. We have just acquired an 80 90 Fiat - the 3 point linkage will raise but will not lower - could it be something to do with the lever settings. We didn't get a manual with the tractor and like you we are not sure what the levers are?
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #8
Put weight on the 3 pt. and see if it goes down. Most just use gravity, no down pressure.
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #9
Most 90 series tracors have a black plastic thumblatch on the right fender, It is a return to depth feature that raises the lift to full up, and operates independantly of the two three point levers. It has a cable that leads down to some linkage on the right side of the lift housing near the rockshaft. Have you tried cycling this latch?
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
84in Grapple Rake Loader Attachment (A56857)
84in Grapple Rake...
20FT X 20FT ALL STEEL CARPORT (A58214)
20FT X 20FT ALL...
5'x8' Rubber Mats (A55272)
5'x8' Rubber Mats...
2002 FREIGHTLINER FL80 (A58214)
2002 FREIGHTLINER...
