Would anyone be able to tell me the different levers in a Fiatagri tractor?
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #1
ektec
town
I'm new here so excuse me
If so please reply, I'm talking about the levers on the right side with the hitch, liftarms clutch brake etc.. I need to know which is which
Cheers.. I can PM you picture if you need photo
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #2
Try them and find out.:eek:
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #3
Which model?
I have a 100 90 DT I can speak to that.
Which model?
It's a 110 90dt... Im sure they are the same?
If you can help it would be great
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #5
G'day post or send me a pic of the levers you are talking about and we will see how we go
Jon
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #7
I was wondering if you received an answer to your question re the levers on the Fiatagri tractor. We have just acquired an 80 90 Fiat - the 3 point linkage will raise but will not lower - could it be something to do with the lever settings. We didn't get a manual with the tractor and like you we are not sure what the levers are?
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #8
Put weight on the 3 pt. and see if it goes down. Most just use gravity, no down pressure.
   / Would anyone be able to tell me the different levers in a Fiatagri tractor? #9
Most 90 series tracors have a black plastic thumblatch on the right fender, It is a return to depth feature that raises the lift to full up, and operates independantly of the two three point levers. It has a cable that leads down to some linkage on the right side of the lift housing near the rockshaft. Have you tried cycling this latch?
Unused 20x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 20x20...
1621 (A58375)
1621 (A58375)
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58216)
2012 TOP HAT...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
