Worth building something with?
/ Worth building something with? #1
jdom84
Montana - the frozen north
LS xj2025h
I got these forklift parts for free the other day... are they worth building something with or should I just eBay them?
/ Worth building something with? #2
Pump might be worth keeping. But it might also have a odd drive shaft. Some odd spline count or flat tang that might not be worth fooling with.
Unless you have something that is 24v, or a cheap way to generate 24VDC at some pretty high amps.....I'd probably just sell
/ Worth building something with? #3
I would at least pull the pump off it to see what it had for a shaft and if I could adapt a gasoline engine to it :)
/ Worth building something with? #4
How about using two matched 12 volt batteries in series to give 24 volts? Charge them one at a time with a 12 volt charger. It might make a good power unit for a dump trailer- of course you would also need a hydraulic cylinder and a reservoir... and a trailer :)
I had actually taken it apart and tested it before thinking about selling it or using it. It has a flat tang style shaft. I was thinking about a power unit but not for a dump trailer, I have a 12k sure-trac. I was also given 2 powered wheel chair/scooters that use 24v to power the two drive motors, I was thinking of building a small tank like vehicle with this motor and pump mounted on it. It could be a mobile power unit for things like shop press or anything else that could use hydraulics... but then I asked myself why? its not like I have extra time just laying around. And i'm not sure how useful it would actually be.
/ Worth building something with? #6
My garage has some stuff I drug home for those "gee, I could make a.........." projects. The two main problems are 1) I don't seem to be able to find enough time and 2) with the case of something like you have there, I'd hesitate to build anything around a more or less proprietary power source because sooner or later it'll go tango uniform and finding a replacement could get expensive. Then I'd need to redesign.
/ Worth building something with? #7
Dump trailer for sure.
Rake Mini Excavator Attachment (A61572)
Rake Mini...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2020 Ford Explorer SUV (A61574)
2020 Ford Explorer...
