Worst weld ever
/ Worst weld ever #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
Worst weld ever? We have a winner!
(Source).
/ Worst weld ever #3
Actually the true purpose is to keep small rodents from going under the truck :). I couldn't weld that bad if I wanted to LOL
/ Worst weld ever #4
Probably works good for snagging the plastic bags lying in the road. Eco weld.
/ Worst weld ever #5
It looks like a rodent welded it.
/ Worst weld ever
Looking at the photo again I wonder if some of that wire came through from the opposite side, extended through burn holes before his arc began. ???
I hope he didn't buy his welder to build a trailer.
/ Worst weld ever #9
(Source).
What? That made me laugh. Wire welding without heat - somewhat common in the beginning. We could call it pulse or spark welding. Saving on cost of electricity. That is truly "wire welding.
/ Worst weld ever #10
I’m trying to understand what the purpose of the weld is? Looks like a skid plate that’s already bolted on to me.
/ Worst weld ever #11
I saw the title and came to say I think I could beat it, I was wrong.
Does look like the rats packed it in there...........
Best,
ed
/ Worst weld ever #12
Is there any actual welded metal there?...It looks lit an arc was run using plain wire (non flux core) with no gas...?
/ Worst weld ever #13
Gentlemen...That's not welding - it's sewing! You can the threads poking out! Geez!
/ Worst weld ever #14
Is that bad welding or sewing with mechanics wire? Look like the wire was laced up in there pretty well.
/ Worst weld ever #15
A rusted out floor pan "repair"? Looks like he secured a new pan or sheet metal piece with a sheet metal screw then tried welding the rust back to the underside to "secure" it permanently & keep it from spinning around on the inside.
/ Worst weld ever #16
Agreed it is unbelievably inept. However, you can't blame a guy for trying. If I never had picked up welder and tried, I might have done something similar........ Nah, I'd have probably done better. If my 6 year old grandson never had picked up welder and tried, he might have done something similar.
/ Worst weld ever #19
It is called the Dunning–Kruger effect,
I worked with a guy in maintenance dept that thought he was a heck of a welder, He would fill in bad spots with silicone caulk and paint with silver paint when no one was watching. He finally went on to another line of work.
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2015 Mack GU713 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
