Worst stuck pics
/ Worst stuck pics #271
Spring rain too. It was a low spot. I just figured tractor could go through. Comes longs are are skow, but amazing what they can do. Need to replace pawl on my smaller one. I also went to tractor supply and bought 3ton for $175.
/ Worst stuck pics #273
For me it took 2 days until1030, lucky big moon, and a couple evenings.
/ Worst stuck pics #274
That's what we call belly hung.:confused2:
/ Worst stuck pics #275
Well I finally did it. Felt the front drop, went to back up and back end dropped. Got the wheel loader up on high ground, should have been no issue but hooked up the chain backed up 4' and belly panned the wheel loader with no bucket on of course. Get the cat had a heck of a time getting the wheel loader out, pull the little tractor out then clean up the soupy mess into something sort of resembling a ditch. I didn't get any more pictures because after the wheel loader dropped it just happened to be shift change at the mill and it was just embarrassing at that point.IMG_4429.JPG
/ Worst stuck pics #276
Bet pressure washer would come in handy. ;)
/ Worst stuck pics #277
Haha. Cleaning the wash bay floor drains was the next job for the tractor before I took it home so I'm lucky that way.
/ Worst stuck pics #278
"Occasionally remove any installed wheel weights and check lug bolts for proper torque." And see if the bolts are still there! What lugs.jpg
/ Worst stuck pics #279
Almost forgot to post this here. Couple weeks back I was mowing a steep hillside that goes into a swamp. Ended up back too far into the muck and got stuck pretty good.
Took about 4 hours to pull it up the hill with a come-along. Had to leave the rotary cutter behind and recover it separately. The rear tires just piled mud over the deck as the tractor sank.
/ Worst stuck pics #280
[/IMG]
Everyone needs one of those types of "stuck" in order to appreciate what not to do. My time was 30 years ago and it took me all day to get things out in pieces like you did. Lesson learned to not do that again.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2014 PJ TRAILER GOOSENECK TRAILER 40' (A60736)
2014 PJ TRAILER...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
iDrive TDS-2010H...
2013 Case 850L (A60462)
2013 Case 850L...
CFG QK20R (A60463)
CFG QK20R (A60463)
