worn valve srpings
/ worn valve srpings #1
cpdtwo
apache junction,az
yanmar 1500d
belive I have worn valve springs on my 1500d. does anyone know what the presure is on the valve springs. I did order new ones but still would like to know what the spring presure should be. so when the new ones come and it does not correct the problem I could check the new springs. the valve are good and I'm replacing the seals so I hope the springs will stop the valve leaks.
/ worn valve srpings #2
How much valve spring tension you have has nothing to do with the valve's ability to hold air/water as long as the valves are closing. You need a valve grinding job.
Have the head in shop, he checked valves say they are fine but springs are only 18lbs and not holding closed, tried shimms but would take too many to close. thats why the new springs but still need to know the correct valve spring lenth and pressure. The lenth new and minume leth for used, the coil lenth is what causes the tension and gives the return presure.
/ worn valve srpings #4
I would have to disagree with that. The valve spring tension has everything to do with how well a valve seals. Not enough spring pressure and the valve might not seat. You need two things for a valve to seal properly. A good valve sealing surface and proper tension from the spring.
cpdtwo - I'm not sure what your springs should be but if you have the head in the shop and they have already tested the old springs on a valve spring tester then they should be able to test the new ones and let you know what they are.
/ worn valve srpings #5
FWIW: I've done a few Yanmar heads and on the very first one I was alarmed at how easy it was to apply pressure, with the palm of my hand, and open all of the intake and exhaust valves. I'm guessing 25-30#'s maybe?
After grinding the seats and valves I ordered all new springs (and seals), cleaned and reassembled the head and there appeared to be no noticeable difference testing the pressure with the palm of my hand. I made the assumption that Yanmar engineered a softer spring intentionally, rather than transmitting the pounding effect through the push-rods, cam followers and, ultimately the cam lobes via stiffer spring tension.
I do understand how a spring will become weakened by a tractor with several thousand hours...or one that has set for many years, valve under load, and collapsed from being in the open position.
Mark
/ worn valve srpings #6
Mark
The next head you do, invert the head, drop the valves in the holes and fill the combustion chamber with liquid. I bet it will hold if you have a good grind job. Not to mention the compression pushing against the valve in a running engine. All the spring has to do is close the valve at the proper time so it can build compression. The seat and compression handle the seal. (IMHO).
/ worn valve srpings #7
Norm,
I drop the valves in the bare head, fill the valve face area with 100 cc's of fuel and leave it that way the remainder of the day. With the gravity of the valves only, and a good valve seat and face grind (hand lapped with fine compound) it has yet to leak on any valve job I've done so far.
Going one step further I also assemble the head and inject air into the intake and exhaust ports with fuel on the valve faces double checking for air bubbles. Again, great success with the ones I've done.
DID LEAK DOWN AND LAPPED VALVE AND STILL LEAKING. THAT THEN LEAVE SPRINGS
/ worn valve srpings #9
mark777 said:
Norm,
My point exactly, I never did one, but that's the way the hotrodders used to "CC" the combustion chambers back in th old days. With a steel valve face against a steel seat, all the spring tension in the world won't improve the seal.
/ worn valve srpings #10
If you got weak valve springs, the valves can float under pressure and the valves will not properly close and you could loose power.
nice what did you find? and this has to do with worn valve springs how?:confused:
/ worn valve srpings #12
Interesting how the efficient TBN staff eliminated that goof-ball in a big hurry. Of course now your post looks a little distant to the nut who replied with links that had no bearing on your thread :).
BTW: I agree that 18#'s of spring pressure it too weak. I wasn't suggesting or implying you can get by with weak springs. Just simply generalizing on how I do my heads.
Mark
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
