worm fence
/ worm fence #1
woodmills1
hudson, NH
kioti LK3054
anyone ever build a stacked split rail or worm fence. i have some triangular white oak sawmill slabs that look like split rails. i wan't to try some fencing with them, any ideas or help?
James "woody" Mills
/ worm fence #2
James,
You probably know this but first remove the bark!! To make the fence last longer you need to place a large stone under each stacking corner. This is primarily to make the fence last longer. You can also use them to even out some of the lower areas. Now if you can, try to use as much locust as possible. It will then last for years. Once you get it to the desired height, you need to put a stabilizer on each side.
I've never built one, but this is what I've observed and read about them.
Terry
/ worm fence #3
James, I seem to remember there being a demonstration stop along the Blue Ridge Parkway where a few different split rail fence designs were on display. There are also examples in Cades Cove in the Smokies. Seems like there should be at least pictures on the all mighty web somewhere, but about all I could find was at:
http://www.splitrail.com/yourself.html
Chuck
/ worm fence
here is a shot of the test worm fence. My dad and I, in the picture) put this up in under an hour just before dark this afternoon.
James "woody" Mills
/ worm fence #5
How do you end up with sawn triangles for slabs? Are these from sawing for quarter-sawn lumber? Or a by-product of sawing for the barrels (seems I remember you supplying barrel parts). Just curious. I remember splitting white oak 10' logs for some rail fencing I supplied several years ago. Splitting them was 'work'!
/ worm fence
yes they are the first cut off of the quarters so they have a triangle cross section. i could make them slightly larger if i thought there was a market for them.. otherwise they would be slabs. don't need no more slabs.
James "woody" Mills
/ worm fence #7
Yep, looks like you got the general idea. Looking pretty good!! /w3tcompact/icons/smile.gif
I see that you have one end with stabilizers (lack of a better term). Does it seem to help at all?? Also, I did not detect any stone under the stacks. I guess for testing purposes they're not needed.
Terry
/ worm fence
i had stones ready and close, but chose to put small chainsawn sections under the bottom rails. after dad and i talked about snow plows we put up the corner poles. no nails, i cut some wedges from leftovers. i can't wait to see what it does as it shrinks. another view.
James "woody" Mills
/ worm fence #9
That's a nice looking fence. Will there be any climbing flowers or even scarlet runners planted by it?
Egon
/ worm fence
in the spring i plan to till on both sides and transplant from the rest of the yard. the previous owners left many established flower beds. just not in places that make for good tractoring. like both sides of the driveway are lined with perrenials. one good snow and whoops there they go. i plan on saving any that survive the winter.
James "woody" Mills
/ worm fence #11
Around here, the wing on the snowplow truck would have that fence moved back a few feet on the first pass widening the road. Hopefully the macadam road shown in the picture isn't indicative of that happening to your fence. It looks nice, and sure will dry the wood nice if you ever need an emergency supply for the wood stove.
/ worm fence #12
James,
The wedges will work as I can now see. However, if you use stones, you will not wick up moisture from the ground and it would minimize the possibility of termites finding a new home.
Terry
/ worm fence
thanks terry, forgot about those critters
James "woody" Mills
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
2017 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
