worlds most expensive mole trap
/ worlds most expensive mole trap #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
found a dead, fairly large mole, floating in the wifes swimming pool today...wasn't there yesterday, an this isn't the first one i have found over the last 7 years....usually they are pretty small an end up in the skimmers...but this was the biggest one i have seen...tried to revive the poor thing, but it was just to far gone!!!
heehaw
/ worlds most expensive mole trap #3
heehaw
heehaw the mole had to do something to get away from your ant infestation.
ken
/ worlds most expensive mole trap #4
We were going to swim in our pool for the first time on Sunday, but there was a big old dead squirrel at the bottom of the pool. So I had to remove it, blast the chlorine level and run the filter for two days just to be sure. YUCK!!! :p:p:p:p:p
/ worlds most expensive mole trap #5
Heehaw, did you try mouth to mouth?
tried shock therapy...threw it high in the air, into the pasture to see if the shock when it hit the ground would stimulate its breathing...didn't seem to work?? haven't seen a single ant in the house in a while now....i did put out some combat bait traps to see if that would reduce the quantity of ant hills all over the yard, hope it works..
heehaw
/ worlds most expensive mole trap #7
heehaw
Think some of your moles have moved into our yard. Want them back?
Ken
no no no...still have a lot more than i want: gotta get serious about settin the traps to get rid of these pest:
heehaw
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2026 Electric Tricycle (A64194)
2026 Electric...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
