Workmaster 55 Fuel Solenoid Relay
   / Workmaster 55 Fuel Solenoid Relay #1
Fireman_Mike
John Deere 950
Can someone tell me what all is on the relay for the fuel shutoff solenoid?
Or tell me where to find a wire diagram?
If I jump from the hot wire to the pink fuel shut off solenoid wire it works 8-10 times then I have to jump across it again. That's all with leaving the relay in. I have tried replacing the relay with no luck.
   / Workmaster 55 Fuel Solenoid Relay #2
I've been through this a number of times with the early Workmaster series. Is this your first issue with this circuit?
Yes. One guy told me to use a jumper wire and forget about it.
   / Workmaster 55 Fuel Solenoid Relay #4
I've made that suggestion before because it works. You may be on the right track here, but I put the jumper wire in and leave the relay out.
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
