Working Solo - Handling 24' Horizontal Tin Siding
   / Working Solo - Handling 24' Horizontal Tin Siding #11
Yes. If I had it to do over, I would specify vertical siding instead but this is the way the kit came from the metal building store so here I am, dealing with it and lack of help. My DW will be there to help carry the pieces over, she's a fine sturdy Irish lass, but if needed they are not too heavy for this 72 year old to tote. Nice shelter BTW - make a great firewood shed too, maybe with a bit of a shed roof overhang on the open side. I like it!
You can always trim the metal panels to length and install them vertically. I had to trim standard length R-panels to get them fitted on that shed I built. I ordered them from Home Depot and got "free" delivery.
Thanks. I did consider that and I may do it for the second shop but this one is almost done with the long horizontal panels (five of six are up). I may do the back wall and front wall with the vertical panels, if they line up with the studs. If the studs line up, or if I add girts along them for fastening, there shouldn't be any waste cutting them as the sidewalls are 9' but I have a roughly 1' clear panel along the top, so 8' of tin. Since I was provided three 3' coverage panels per side I should get nine 8' panels per side to give me 27' of coverage - an extra 8' panel per side.
Certainly a thought. I'm sure I'll have to add girts to make the vertical work though and that will be a slightly higher expense for the 1x boards - metal will be too expensive.
Once roofed a indoor riding arena using the Vicegrip technique, sheets were 23 ft long and we'd lean 2 x 4 at an angle so as to not crease the metal panels.
A pulley nailed at the top and long rope completed the apparatus. Worked great with never a crease or kink, and that arena was 200 ft long!
Called working smarter!
Oh, and we'd pre drill the screw holes (using a jig) 5 sheets at a time so that the screw guy never missed a purlin. Also from the ground looking up the screwline pattern was real pretty.
Thanks for that. That is my plan for getting the roofing up - those panels are much more manageable than the side panels since they are only just under 10'. I do like that you confirmed that my idea is valid, thanks for that.
I also love your idea for pre-drilling the roof panels I will indeed do that. The sides are easy to keep level and straight just using a chalk line.
(INOP) 2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DU (A51406)
(INOP) 2008...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
2013 BMW X5 xDrive35i AWD SUV (A55758)
2013 BMW X5...
Giyi 40" Mini Sweeper (A53316)
Giyi 40" Mini...
2006 Toyota Tundra 4X4 Pickup Truck (A55788)
2006 Toyota Tundra...
