Working rail roads and their tracks.
   / Working rail roads and their tracks. #1,691
Two guys pushing.
In the steam era it was often done by turning a hand-wheel or two and a gear train to rotate the table. btw, TTs in the UK were typically shorter as steam engines were shorter than ours. Not all had tenders because distances were shorter and fuel was plentiful. Coal was a most common freight commodity, so was always accessible.
   / Working rail roads and their tracks. #1,692
I have a friend that's about 15 years older than me. When he was a kid back in the late 40's/early 50's, his father had a job working for a RR and he had to move the engines in and out of the roundhouse, onto the turntable, then over to a pit to clean out the fireboxes. My friend said he has fond memories of his dad putting him up in the engine, then going over to the hand crank to rotate the engine to the appropriate track. Man, that would have been fun.
   / Working rail roads and their tracks. #1,693
That's the area that Hay Dude showed them putting in a new commuter station.
You should see it now…..
   / Working rail roads and their tracks. #1,697
   / Working rail roads and their tracks. #1,698
My late grandfather mentioned a few times an abondoned narrow gauge railroad and engine in the middle of nowhere in the UP, used for logging, I've never found it nor do I know if it's still there. But he did bring me out to what was left of an abondoned model T in the middle of BFE same grandpa also took me to a long abondoned fordson steel wheel tractor, along with a broken horse drawn road grader, I believe that's what they were. Miles off any driveable road in the woods, I think they were his when he logged. It amazes me still, what one can stumble upon in the middle of nowhere.
   / Working rail roads and their tracks. #1,700
Nice. If you look on google earth, I think you may be able to see some of the stall foundations still in the parking lot. That wagon wheel spoke pattern. Those white lines. Might not be, but worth a look back.
I'll have to call it up on the home PC and go back in history to see if that can still be seen.
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
