Working pressure of BX22 Hydraulics?
   / Working pressure of BX22 Hydraulics? #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
Does anyone know what the working pressures are in a BX22 hydraulic system. I am in need of a cylinder for a project and the one that I have found is a 1500 PSI one. Don't want to blow it apart if the BX has a higher output. I have tried to find a cylinder that is rated for 2500 PSI, but they aren't available in this small size. Thanks..... Junk....
   / Working pressure of BX22 Hydraulics? #2
I'm about 99% sure it's 1840-1890 psi. I could check the manual when I get home(I know I posted it here once or twice before).
   / Working pressure of BX22 Hydraulics? #3
The hydraulic relief valve setting on a BX1500 is 1778-1849 psi. Not sure if the BX22 is identical.
Do you think that I could get away with using a cylinder that is rated for 1500 on the system??? Is there an "safety" margin built into them? I have been unable to find a 1 1/2 x 6 cylinder with clevis ends on it in any other pressure except for a tie rod cylinder and that won't work in this application. I need the welded cylinder..
   / Working pressure of BX22 Hydraulics? #5
   / Working pressure of BX22 Hydraulics? #7
I have a copy of the workshop manual for the BX23 and BX22 and the main relief valve pressure is listed as being the same - 1778 - 1849 psi. I looked very quickly at the backhoe section of the manual and I think it said something in there about a relief valve and it had a higher pressure listed - over 2000 psi.
Bill...... I have the welder, helmet, and wire. I don't have the inclination to do any welding at this time. Too many other things to do. Besides, I don't like the idea of welding on a cylinder.
I looked at the link that you have provided, but I couldn't find a 1 1/2 X 6 welded cylinder. I also have the problem of the overall length. I can only use a 12" approximate over all length. If you could supply me with a part number, I would be grateful... thanks. .... Junk.......
   / Working pressure of BX22 Hydraulics? #9
Junkman,
When I click on it that link in the post above takes me to the Prince web page that shows the following cylinder (second one from the top):
F150060CSSTCC-B (Prince part number)
1 1/2" Bore X 6" Stroke (Wizard Line)
3/4" Dia Rod, 15" Retract
Clevis end fittings For 3/4" Dia. pins
9/16-37 JIC Ports.
Distributor Surplus - New in Box
$80.20 net ea
The retracted length of this cylinder without the clevis ends is 11.5 inches.
I'm not sure but it might be difficult finding a cylinder with clevis ends that has a stroke of six inches and a pin-to-pin retracted length of 12"...
The welded on clevis ends add about 1.5 inches each to the retracted length...
Hope this helps...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
Ran during check in. No longer running. (A51694)
Ran during check...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
1270 (A50490)
1270 (A50490)
