Working on tractor with loader up...do you?
   / Working on tractor with loader up...do you? #1
Redbug
Columbia, SC
Kubota L3830HST
What do you folks do when working on your tractor and the loader arms are in the way? What is the safest procedure...lift the arms and use the valve lock safety and work under the raised loader? How reliable is the valve lock, safety wise? I am wondering, since I am not sure. It seems like some kind of physical lock...like a pin in the frame or something would be more reliable but mine has none. Suggestions? Taking the loader off, seems like a pain in the rear.
   / Working on tractor with loader up...do you? #2
I was going to day taking it off before I read the end of your post. If you are not taking it off, then I wouuld find a way to block it up. I still have some 4x4s left from when I built my deck. They come in handy if I need to do what you are describing.
   / Working on tractor with loader up...do you? #3
I assume you have a quick attach loader. I would remove it for safety and ease of working on the tractor. Most are 5 minutes off and 10 on.
   / Working on tractor with loader up...do you? #4
The quick clean the screen in front of the radiator, and such I just use some blocks. When I replaced the very expensive radiator I took off the arms/bucket.
steve
   / Working on tractor with loader up...do you? #5
I for one would chain the bucket to something solid,or rest the bucket bottom flat on somthing high plus use the E- Brake.
   / Working on tractor with loader up...do you? #6
I work under my loader all the time... IF it is cribbed or blocked with a fence post or other large wodden brace.. jackstands and hi-lift jacks.. etc... Never just on HYD's.. .. never on -just- jacks either.. got to have timber or stands.. or both.
Soundguy
   / Working on tractor with loader up...do you? #7
Dealer showed me a trick he uses. Take a piece of angle steel and zip tie to the ram on the hydraulic cylinder of the loader. If loader starts to go down, the piece of angle will catch it. Of course make sure the steel you use has no burrs on it.
   / Working on tractor with loader up...do you? #8
On most of the equipment I have used that requires you to work under a gate or hydraulic implement (round baler and such) they usually have a piece of C channel that flips over the extended ram and you pin it so it can't flip off. Similar to the angle iron but it covers the entire exposed ram and you are not relying on plastic ties to hold it on if something lets loose.
On my 1920 and TN I just hop under the loader arm when it is on the ground and do what I need to. If it is going to be something major I will just pull the loader off.
Thanks Guys,
I do have a Quick Attach on my bucket, and that is a good idea...just unattaching it before raising the arms. That would lessen the danger of most of the weight. I would have never thought of using the angle iron with tie wraps! I think that's what I will do next time. I have plenty of angle iron in my workshop and will cut a couple pieces just for that purpose. Great ideas to be safe by.
   / Working on tractor with loader up...do you? #10
My batwing mower has angle guards like that that flip over the lift ram so you don't loose hyds and bottom out going down the road. The wings have arms that pin up to hol dthem also..
Soundguy
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
JOHN DEERE 7210R LOT NUMBER 259 (A53084)
JOHN DEERE 7210R...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
SCAN TO RECEIVE TEXT UPDATES (A51247)
SCAN TO RECEIVE...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
