Work Tunes
/ Work Tunes #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Good Mornin Guys,
My old work tunes finally died, even took it apart to no avail, but Im not an electronics guy, so I dont knw what that proved ! :)
I just got my new Northern catologue, and see they have a have a set of digital work tunes for sale. Presets and all, way fancier than what I had before, but for $49.99 it sounded like a prett good deal...
Have any of you guys bought this set and if so what are your feelings ? Im thinking the digital presets must be nice, we have two pretty good country stations that I can get while mowing the field, 107.1 and 107.7, so i really dont need 10 presets, but who knows...
Thanks for your comments ! :)
/ Work Tunes #2
I have the deere branded worktunes with the digital. They work well. Tuner isnt quite as good as I hoped, but if you have a few strong local stations you should have no issues tuning in anything.
I'd give them a 8/10
/ Work Tunes #3
I have been using the Peltor Work Tune radios for years for many hours each day. What I like about them is that they use AA batteries, and the rechargeable ones last for many days. Some of them are not 'tuned' [ the receiver front end stuff ] as well as others, and you will find differences in them. There main problem is the 6 wire cable that goes between the two muffs. It breaks after awhile and needs to be replaced. Not that hard to do and have done it many times. I use an old computer ethernet cable which has too many pairs of wires in it, but works. I finally have to throw them away when the plastic ear pieces finally crack and fall apart. But I keep the better tuned radio sections to reuse. I have a pair of Bilsom Hi-Visibility non-digital headphones that also use the AA's. They are a lot more expensive, but have better stereo separation.. and I think a better 'front end' than the Peltors. The Peltors work great, though.... !!! Here is a picture of a junked set, my current one with the new blue wire, and the Bilsom's...
/ Work Tunes #4
Another thing, you can usually get them at Lowe's or Home Depot for that same price [ can't remember which one ]. Amazon usually has them for around $40 or so once and awhile. The Bilsom's are close to $70 with shipping.
/ Work Tunes #5
I have a set of Worktunes digital. They are OK. Nothing special, you get what you pay for. Digital tuner is way nicer than the analogue. I also got a set of Ryobi's I would not recommend them unless you work in a shop where you need to communicate with people all the time.
I seldom use the radio btw, not much radio in our hood.
Ryobi TEK4 :: Audio Plus
/ Work Tunes #6
I too wore out a set of analog work tunes, I replaced them with a digital set. No difference in reception, but the accuracy of the dial is worth it.
Will
/ Work Tunes
Good Evenin Guys,
Thanks so much for all your informative responses...
I will go with the digital set, just not sure which ones, whatever I decide it should be a big improvement over the analog !
Once again thanks for your suggestions !:)
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
207276 (A52708)
207276 (A52708)
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
