Work lights for a BX
/ Work lights for a BX #1
Charliebrn
Platinum Member
NW Ohio
Kubota BX-2360
I've been wanting some work lights for my BX, but didn't want to modify the ROPS in any way, so this is what I did...
Materials:
1 - 12v trapezoid from TSC .... $15
1 - 12v flood from TSC............ $15
2 - Stake pockets from TSC..... $2.20 each (sku 21-17015)
1 - 15' roll of trailer wiring ........$5.50
2 - Weather resistant toggle switches... $5.50 each
1 Foot of insulation foam for 3" pipe
Flatten one of the stake pockets and cut off excess steel that is longer than the other unmodified pocket, drill 2 holes to match the other pocket and a third 1" toward the center, centered between the other two (for wiring to be fed through). Run 3 wires through the extra hole in the top flat bracket, down the back of the ROPS to the underside, twist it to be parallel to the bottom center, and then wrap the foam around the rops. Place the unmodified stake pocket around the foam, and bolt it to the top bracket. The fit will be nice and tight, but wont damage the paint or the ROPS. Hook up both worklights to 2 of the bolt holes, the trapezoid up front, the flood to the rear.tie both grounds to one of the wires(es: brown, the hots to one of the others (ex:green for the front and yellow for the rear light). Mount the two switches to the rear cover, and hook the front hot to one and the rear hot to the other. Run the ground to the black wire under the seat using a bullet connector. Run a wire from the red wire under the seat (which is switched to the key) to each of the switches.
See the attached pictures if I havent' been clear, but the system works great! Each switch controls one of the lights and I won't have to swivel one around constantly this coming winter when I'm moving snow around. And I've got less than $50 bucks wrapped up in the whole project.
What I haven't figured out yet is how to secure the wires to the ROPS better than the zip ties..... Any ideas????
Have fun...took me 2 hours to do...
Scott
Closeup of the mount....
The mounting of the switches...putting them here eliminated running wire to the dash, yet are very convenient and out of the way...
/ Work lights for a BX #4
Very nice install!
Maybe black tie wraps, Thats about your only option to hide it a little. Looks ok now though too.
Any concern on current draw?
How much is ok or too much?
Rogue
/ Work lights for a BX #5
Scott,
Nice job... /w3tcompact/icons/smile.gif
One quick tip, use some silicon RTV to prevent moisture/water entry/damage to back of wiring {into lamp assy} and seal hole in top of rops...
/ Work lights for a BX #6
Scott,
Looks great, I only have one suggestion, flip the lights over so they hang down and they will be protected by the ROPS. (See the attached photo of the light on my B2710). With the light hanging down there is less chance of a tree limb snaging it.
Actually, there is no hole in the top of the ROPS, only in the top bracket (the wiring goes aunder the bottom bracket, around the ROPS and up thru the hole in the top bracket). Anyway, I agree, silicon will be used to seal all the holes once I figure out how to secure the wires. Thank you!
Two 55 Watt halogens draw just a little over 9 amps. The circuit seems to be wired to a 20 amp fuse, so by my reconning, it looks just fine....
/ Work lights for a BX #10
hey charliebrn,
looks good! i need to think of the light thing also for winter. could you drill some holes and run the wires thru the ROPS? if not, the adhesive backed wire clamps would be the cleanest look.
rich
The ONE major thing I wanted to avoid was doing anything to the ROPS, least of all drilling a hole into it. While it would make for a clean install, and I doubt that a couple small holes would negate the usefullness of the ROPS if I rolled her, I can just imagine the liability issue if I were to ever trade up to another tractor....
/ Work lights for a BX #12
use the tie wraps to hold wires where u want them, then in a few spots use silicone rtv.caulk. let it cure then remove tie wraps.
/ Work lights for a BX #13
Very clean installation Scott. Good job.
The post about flipping the lights over is also very good. For routing the wires, a good instrument house has black vinyl covered 1/4" or 3/8" copper tubing, and also 1/4" and 3/8" stainless tubing. If my ROPS was not folding I would put the wire inside the tubing, and strap the tubing onto the rops with really big wire ties.
Scott, Mt TSC flood lamp (looks like yours) is not too much of a flood. It almost has the trapezoid pattern. Is yours a true flood?
jrpoux
jrpoux@wcnet.net
/ Work lights for a BX #14
Scott,
Great job.
If you did mount the lights under the ROPS do you think the forward looking one would effectively work spreading the light? Also, where did you pick up the lights and bracket?
Jim
I tried mounting the lights under the ROPS, but If I turned my head just right or bounced around, I hit it with my head, so therefore, on top they go! You are right about the rear flood, Id isn't much of a flood, but it's enough to see what I'm doing behind me.
I like the idea of the coated tubing though, and I'm gonna try and find some. The could be tough around here, though....
/ Work lights for a BX #16
Here is a picture of the light I installed on my BX2200. Mounted the toggle next to it on top. Works great when running implements at night.
TractorTim
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
iDrive TDS-2010H...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2007 Kubota B21 TLB (A60462)
2007 Kubota B21...
2018 HINO 338 4X2 22FT CDL REQUIRED BOX TRUCK (A59906)
2018 HINO 338 4X2...
