Vitster
:confused2:Bought a large rectangular Blazer magnetic base Work Light at TSC for my B2920. I wanted it for mowing at night with my 60" MMM. I like to see the grass line on the right side real well when mowing, and the stock lights are too far out front. I tried it out hooking direct to battery to see how much light and WOW. Don't really need two of these for my needs. I plan to just use a marine cigarette lighter plug I'll mount in the black plastic fender assembly on right side so I can just stick the light onto the ROPS, plug in the cig. plug, and remove when not needed. I can also move it from one side of the ROPS to other and even shine it to the rear if needed. I'm electrically challenged and am trying to figure out the best way to run my wiring. This light is a 55W/H-3 bulb. Can I assume I have no issues using it with standard alternator on tractor at same time as stock lights? Is there a place under the seat where I can wire to, or is another way recommended? The tractor only has 11 hrs. on it and I haven't done much exploring yet. I wasn't really planning on using a switch. I do however plan to use a fuse, figuring 15 amp since that is the size fuse that came with my spotlight I use on my boat. Any recommendations, or pictures of where wires are on either a B2920, or a B2620, or even a B2320 which I presume would be the same. All help appreciated. Thanks. :confused2:
