Work light bx25
/ Work light bx25 #11
So if I understand this correctly, the BX has the electrical supply under the seat, so all you have to do is attach a switch between that connection and the lights and voila? (Not much into electrical):confused:
The wire connections is right under the electrical tape at the y part. locate your tailight wires and backtrack it to where it meets into a Y. Within the Y part is a folded up wires under tape.
The wires is switched on from key on so no worries about leaving lights on.
/ Work light bx25 #13
newbury- looking at your B pics, the wire loom/y part has same concept as BX. How was your wiring found from the factory on the B? under electrical tape like the BX ?
/ Work light bx25 #14
I don't remember offhand the amperage. I need to get one of those WSM that has all this stuff. When I did my lights, I added a seperate whole new line to battery with inline fuse with a thicker gauge wire. I used the household 14/2 wire as it was a neater way of running wire. I wanted to keep the pigtail free for other 3pt power connections stuff like the sprayer I made.
I did a similiar install but also installed a relay off the ignition circuit into the 12V battery feed, So when the tractor is off, EVERY thing is off...Just incase the on /off switches get bumped during the day.
No need to risk a dead battery...:D
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
New/Unused Electric Golf Cart (A61166)
New/Unused...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
