Work lamp on G3033/workmaster 35
/ Work lamp on G3033/workmaster 35 #1
Cfy7
Upstate, NY
New Holland Workmaster 35
Does anyone have any experience installing a work lamp on a g3033 or g3038? I have the New Holland version and am trying to install one.
I've found that there is a prewire for a work lamp at the back already, but I need a switch for it. I cant find a switch in any parts listing though.
So, Does anyone know where to get the switch or the part number?
Thanks!
/ Work lamp on G3033/workmaster 35 #2
The switch on the LS models.. At least on mine 4041 is on the light itself. Kind of a pain to turn around and find it. A dash switch would be much better.
/ Work lamp on G3033/workmaster 35 #3
Bought an LS light for mine. Wire in back is hot when ignition is turned on. Dash mount would be better, but with most lights, a cheap weatherproof push button could be installed in the light itself. Make sure you put the light high on the bracket, or depending on which setting you have your 3 point hitch set up, your top link may crush your light when lift is raised. I used to have a tool box mounted on the back of mine. Now it is just bent metal.
Alright, that answers it. It's a shame the switch holes aren't the standard size that a lot of aftermarket car fog light switches are. Guess I'll have to rig something up.
Thanks boomer and woodsman.
/ Work lamp on G3033/workmaster 35 #5
Glued my in dash with tick ca glue worked looked fine
Nice! I ended up using a razor blade to cut out a house in the plug that covered the hole, then using some plastic glue to hold it all together.
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
2025 Ranger 1000 XP Northstar Premium (A62679)
2025 Ranger 1000...
Knight Verti-Maxx 5032 Feed Mixer Wagon (A66408)
Knight Verti-Maxx...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
