Work lamp on G3033/workmaster 35
   / Work lamp on G3033/workmaster 35 #1
Cfy7
Upstate, NY
New Holland Workmaster 35
Does anyone have any experience installing a work lamp on a g3033 or g3038? I have the New Holland version and am trying to install one.
I've found that there is a prewire for a work lamp at the back already, but I need a switch for it. I cant find a switch in any parts listing though.
So, Does anyone know where to get the switch or the part number?
Thanks!
   / Work lamp on G3033/workmaster 35 #2
The switch on the LS models.. At least on mine 4041 is on the light itself. Kind of a pain to turn around and find it. A dash switch would be much better.
   / Work lamp on G3033/workmaster 35 #3
Bought an LS light for mine. Wire in back is hot when ignition is turned on. Dash mount would be better, but with most lights, a cheap weatherproof push button could be installed in the light itself. Make sure you put the light high on the bracket, or depending on which setting you have your 3 point hitch set up, your top link may crush your light when lift is raised. I used to have a tool box mounted on the back of mine. Now it is just bent metal.
Alright, that answers it. It's a shame the switch holes aren't the standard size that a lot of aftermarket car fog light switches are. Guess I'll have to rig something up.
Thanks boomer and woodsman.
   / Work lamp on G3033/workmaster 35 #5
Glued my in dash with tick ca glue worked looked fine
Nice! I ended up using a razor blade to cut out a house in the plug that covered the hole, then using some plastic glue to hold it all together.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
kids dirt bike (A56859)
kids dirt bike...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
