whistlepig
Elite Member
Check the shear bolt on the cutter end of the PTO shaft. Make sure that it is in good condition. If this comes loose you may have a PTO shaft powered by a tractor motor flailing about close to the back of your head. This can be very dangerous. Check the blade mounting and stump jumper bolts/nuts. If the blades come loose they can fling in to a rear tractor tire and ruin it (or something worse). Make sure all your attachment points are strong and safe. Always step back after hooking up and double check that something doesn't get missed on the hook up. Be care full where you mow. A mower can suck up a piece of fence or a long strand of barbed wire. This can whip around and suck the operator or bystanders in to the mower. This may sound like overkill but all of the above has happened to me. I was lucky the first time and don't feel like I am owed a second chance.
