Woods M5
/ Woods M5
OK...I'll give it a try. I'll try to get the PB Blaster today...probably will not get to the baldes til next weekend. Thanks for all of the help.
/ Woods M5 #12
NAPA (if you have them) has it, too. The difference between WD40 and PB is that WD40 is a lubricant and PB is a solvent.
/ Woods M5
Picked up the PB Blaster at Checker Auto this afternoon...sprayed a couple of times. 98 degrees here in Minnesota so I'll try to get to them in a day or so...to hot to work in the barn.
/ Woods M5 #14
My M5 is probably in the same, or worse condition. One time, I had to take the whole bar off to get better access and really be able to pound on the pins. The other time, I put a jack under the bar so I'm pounding on something solid and not just causing the whole deck to bounce. When you start to lift the whole deck, you know you've got something solid to pound down on. Now I really grease the pins up before putting them back so next time the job is much easier. Good luck.
/ Woods M5
The first blade change on my Woods M60-4 was a real challenge. I don't think the previous owner ever changed them so it had been some time since they had been off. I ended up using a heavy duty "C" clamp, a large socket and lots of heat. Took two days. Hopefully your efforts won't be as involved. Now the pins are greased at least 2-3 times a season and blade changes take about 5 minutes.
Russ
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2017 Ford Expedition SUV (A59231)
2017 Ford...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
