Woods Rotary Bush Hog Gear Box
   / Woods Rotary Bush Hog Gear Box
I had an old Howes bush hog that used that same gear box and it did the same thing yours did, lower bearing said screw it I'm done.
Anyway it was an easy fix with new bearings and seals, nothing unusual about the way they go together. As long as the housing and shaft is not damaged/ruined I would just repair what you have in hand and probably be a lot cheaper to that as well.
🤠 thank ya!
   / Woods Rotary Bush Hog Gear Box #12
Just guessing but there's a good chance the bottom seal was leaking so rather than fix the problem someone pumped it full of grease and kept running it. How many times have I seen that? It's not necessarily the wrong solution, I've done it myself. The thing is it's not too effective if the bearings aren't still tight. The shims under the blade holder are part of the package to maintain the integrity of the bearing adjustment, so don't overlook that part when you get that point.
Good call, betchu are right. It was packed full of cosmoline.
   / Woods Rotary Bush Hog Gear Box #14
I’ve got a single spindle 286 I bought used that needs the same. Bad seal on a little used mower. Previous one lasted 25 years without a leak. Assembly with correct bearing preload the key to long seal life. Haven’t tackled the rebuild job. Would be a major accomplishment given my skill set. Do have a leaky shop press.
   / Woods Rotary Bush Hog Gear Box #15
The bottom seal on my King Kutter 6'er was leaking badly, so I filled it with 15W40 diesel oil, and ran it lightly for a while, adding oil as needed. The seal stopped leaking(softened up I guess) and the gearbox remained full. Pumped out the oil with a hand suction pump then filled it with chainsaw bar lube. It's remained full for 3 years so far, without making any noises.
   / Woods Rotary Bush Hog Gear Box #16
May be that it was filled with corn head 00wt grease.
That's what I use when I can on my gear boxes, (and have quite a few gear boxes).
As a side note, I'm glad you found your gear box, as it's quite expensive to buy a new, high quality cutter... just paid $30k for one, so I know. ;)
Be sure and check the other gear boxes when you can. New lubricant wouldn't hurt.... bearings and seals are cheaper than gear boxes, and if you had one fail on the cutter, I'd sure look at the others.
Good call RBB! $30k 🤑
2011 Ford Edge AWD SUV (A55758)
2011 Ford Edge AWD...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
Toro Zero Turn (A50324)
Toro Zero Turn...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
