Woods m5-4 rotary cutter
   / Woods m5-4 rotary cutter #1
FilthyOx
Vermont
MF
I have a woods m5-4 and the stump jumper has been beaten up badly, seems to be causing a lot of vibrations.
My local woods dealer wants $208 for the part, is there any cheaper alternatives? Are there any universal or aftermarket type replacements?
Thanks
   / Woods m5-4 rotary cutter #2
I have a Woods 5'er, It is something like a M-60 or some such model.
I replaced the deck and stump jumper about 10 years ago.
I made my own jumper from 1/4" steel.
I cut a round circle and went around it and hammered the edge up like it should be.
I did it cold but don't remember much about how I did it. ???
It's still working!
Two hours to remove this sucker! Any thoughts on if it's salvageable?
   / Woods m5-4 rotary cutter #4
I would toss it and run without it. you may need to shim the pins or get shorter pins.
   / Woods m5-4 rotary cutter #5
If this guy cuts land that caused the original damage to that stump jumper, I'd definitely get a new one! Or he'll be replacing a spindle. Unless the OP likes to cut and weld, in which case he'd not have asked about it.
   / Woods m5-4 rotary cutter #6
These are NOT finish mowers! They are meant for serious cutting/clearing.
The Stump Jumper is mandatory on my cutter. I will back up and lower on bushes and 2" saplings and mow them to the ground.
You can't do that without the jumper.
If the OP can't fabricate a new one then it's time to pay for one.
Yeah I will say my property grows more rocks than grass so a stump jumper is a must for me.
I am going to take what's left of it and bring it to a welder and see if they can help me out!
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
