Woods m5-4 rotary cutter
   / Woods m5-4 rotary cutter #1
FilthyOx
Vermont
MF
I have a woods m5-4 and the stump jumper has been beaten up badly, seems to be causing a lot of vibrations.
My local woods dealer wants $208 for the part, is there any cheaper alternatives? Are there any universal or aftermarket type replacements?
   / Woods m5-4 rotary cutter #2
I have a Woods 5'er, It is something like a M-60 or some such model.
I replaced the deck and stump jumper about 10 years ago.
I made my own jumper from 1/4" steel.
I cut a round circle and went around it and hammered the edge up like it should be.
I did it cold but don't remember much about how I did it. ???
It's still working!
Two hours to remove this sucker! Any thoughts on if it's salvageable?
   / Woods m5-4 rotary cutter #4
I would toss it and run without it. you may need to shim the pins or get shorter pins.
   / Woods m5-4 rotary cutter #5
If this guy cuts land that caused the original damage to that stump jumper, I'd definitely get a new one! Or he'll be replacing a spindle. Unless the OP likes to cut and weld, in which case he'd not have asked about it.
   / Woods m5-4 rotary cutter #6
These are NOT finish mowers! They are meant for serious cutting/clearing.
The Stump Jumper is mandatory on my cutter. I will back up and lower on bushes and 2" saplings and mow them to the ground.
You can't do that without the jumper.
If the OP can't fabricate a new one then it's time to pay for one.
Yeah I will say my property grows more rocks than grass so a stump jumper is a must for me.
I am going to take what's left of it and bring it to a welder and see if they can help me out!
JLG MANLIFT (A52472)
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
JOHN DEERE TS LOT NUMBER 151 (A53084)
JOHN DEERE TS LOT...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
