woods loader 1009 parts?
/ woods loader 1009 parts? #1
duksrule
HELP.........
I have a John Deere 4200 tractor with a Woods 1009 Loader. I bought the tractor with the loader on it used. It has always worked great but now I need some parts for the contol valve. I assumed that the loader control valve was a woods model sinse it is mounted to the loader frame on the right side of the tractor. I know the John Deere controller on this tractor is under the seat. So I call Woods and they tell me they never made a controller for the 4200 and they just plumb the loader into the John Deere valve. Well I am at a loss. Does anyone know how I can get parts for this thing? I actually need the rods (about 1 inch long) that are on a ball bearing sort of ball that connect the actual control stick to the valve itself. I called woods and called John Deere. Now one has a clue.
The valve says SAUER DANFOSS 4400 15682255
/ woods loader 1009 parts? #2
Picture?
Have you called woods and asked for a parts breakdown?
I am assuming that you have had no luck because you are using the wrong words. Used to be you could discribe the part and have an intelligent counter person figure out what you need, but nowadays you need to tell them exactly what you need.
Picture?
I called woods and they said that they never made a valve for the 4200 so there is no breakdown to send me. They said the dealer could have used any vavle. That seems odd to me that a dealer would get the loader from woods but then just stick a random valve on the tractor. I am at the end of my rope.
/ woods loader 1009 parts? #6
Post a picture and I can tell you if it is woods or not.
/ woods loader 1009 parts? #9
Sir did you ever find parts for the woods 1009 loader control? I also have a woods 1009 and just broke the cast aluminum piece that raises and lowers the pistons in the valve.
Thank You
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2013 Honda 250 Recon ES ATV (A64557)
2013 Honda 250...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
