Woods Implement Paint
/ Woods Implement Paint #2
go to the paint company color charts and match the color
/ Woods Implement Paint #4
Google this......Rustoleum industrial tractor yellow
cant beat the quality and lots of yellows to choose from.
If its more than touch up the paint can be brushed on and look as if its been sprayed.
/ Woods Implement Paint #5
If you have rust, I would suggest
1) use a wire brush (one mounted on a drill or angle grinder works well) wipe off with a paint friendly cleaner—it is a pain to have to degrease in order to get paints to adhere.
2) apply a rust convertor (your choice of brand—there are lots out there)
3) use a decent primer—the cheaper you use the less well it holds to the metal and final color coats of paint (I like a self etching primer—these hold to metal/rust converted metal and cover coat well) For touch up work I usually use rattle cans. Mostly do to being lazy to mix and clean up paints for the air sprayer. With rattle cans I can be done not counting waiting between coats in the time it takes to prep with the spray gun.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
219065 (A65056)
219065 (A65056)
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
