Woods BH6000 on BX Question
/ Woods BH6000 on BX Question #1
CHDinCT
Veteran Member
Conn. & Florida
Kubota BX25, Z422-KW
For anyone who owns this backhoe for their BX, can you tell me if the stabilizers are in the up or down position for storage (when off the tractor)? In looking through the owners/installation manual, it shows a pic of the BH6000 in the storage position with the stabilizers up. Per my dealer, the Kubota BH on the BX25 stores with the stabilzers down or out. If the Woods stores with the stabilzers in the up position, I might be able to get it in my shed and not have to store it outside.
Still thinking about buying the Woods BH for my BX1860 or trading up to a BX25. Thought I had my BX sold last weekend, but the guy backed out at the last minute. Thanks
/ Woods BH6000 on BX Question #2
You need to have the stabilizers down to take it OFF the tractor. It does not need to be down for storage. I would HATE to leave it down due to rusting of chrome on the cylinders. I always retract them after taking it off the BX24. Same would go for BX25.
Hey, thanks for that info. I knew they had to be down for removal, but they said that they stay down and out for storage too on the BX25. So the BH won't fall over with the stabilizers retracted? Good to know. Thought this was a difference between the two models. Also, forgot to ask, does your BX have float on the boom control valve position? The Woods does.
/ Woods BH6000 on BX Question #4
Chris - You may have already seen one of these but I would suggest the BXpanded backhoe dolly for what you need Backhoe Storage Dolly. The stabilizers are stored in the up position since the dolly supports the BH from tipping over. Once you have removed the BH, you can wheel the dolly to a storage position of your choice. Attached is a picture of my BH using the BXpanded dolly.
Tod
Tod
Tod, thanks for the pic. I would definitely need to buy or make a backhoe and loader dolly so I could move each to a corner of my shed where it would be impossible to mount or dismount them, but it wouldn't work if the stabilizers had to be down. I would guess the BXpanded BH dolly would work for the Woods hoe and if not, I'm sure it would with a little modification. By the way, does your BX backhoe have float on the boom circuit?
Was reading a Cub Cadet Yanmar brochure where they seemed to make a big deal of that feature on their SC2450, but it turns out Woods also has it and I'm guessing so does Kubota.
/ Woods BH6000 on BX Question #6
Chris, I have to show my lack of knowledge on your question about having a float feature on the boom circuit. If it has it, I've never accidentally found it or read it in the manual. Hopefully someone else can confirm if it has it or not.
Maybe Harry (BXpanded) will chime in on this thread on whether he has tested his dolly with the Woods hoe.
One item that I want to point out about my picture, that I have taken care of, is that the bungee cord holding the stabilizers up isn't the best solution. It never leaked down but I now use a ratchet strap for extra insurance.
/ Woods BH6000 on BX Question #7
I think you would be far better off getting a BX and the BXpanded dolly. The dolly is the only way to take off the hoe. It is made specifically for the BX hoe so talk to them before you get one for a woods unit. I feel stupid but I don't know how float would work on a backhoe and I am on my second one!
/ Woods BH6000 on BX Question #8
The Woods BH6000 is a bit more persnickety to get on than the Kubota bh that comes on a BX 22, 23, 24, 25. I made the holes in the stabilizer pads a bit larger and use bolt on wheels. I also built bolt on skateboards for the end of the boom and the base of the bh body. This allows me to move everything easily into precise alignment when reattaching. I use a compression strap to prevent the stabilizers from dropping due to bleed down.
http://www.tractorbynet.com/forums/...ting/161320d1270971467-bota-cave-bh-dolly.jpg
http://www.tractorbynet.com/forums/...ting/161321d1270971467-bota-cave-bh-dolly.jpg
This has been discussed a kazillion times, but if you already have a BX with 4 digits, adding the Woods is the way to go. If you do not have a BX and are buying new, getting the BX with 2 digits (bh comes with it) is the way to go. You do not need a bigger BX to use this bh. Here's a BX1500 moving boulders and digging out stumps with this same bh:
http://www.tractorbynet.com/forums/kubota-owning-operating/54527-bx1500-woods-bh6000.html
/ Woods BH6000 on BX Question #9
I have dealt with taking a backhoe off and on for several years now, not on a BX and not the backhoe mentioned, here is what experience has taught me:
rust has not been an issue at all in more than 15 years.
seams like they always settle, and more times than not, have fallen down after a few months. (this is with trying to support it up on the big chimney blocks or a tire rim and a few other things)
I'd say put some plywood down tho keep it out of the dirt (not that matters either) and settle it down. next spring (or whenever) let the hydraulics lift it back up and put it in position to remount.
Thanks guys for responding. On the float position, I believe if you have it there would be a detent on the stick that controls the boom raise/lower. For anyone with a BX, if you could push the stick to the boom lower position hard and see if it goes into a detent (stays in the lowering position). If so, it would have the float feature. In reading the Woods manual (downloaded it from their site), it states something about using float to dig a flat bottomed trench, if I recall correctly. I suppose putting the boom in float you can dig with the dipperstick and bucket and the boom will float up an down as necessary.
Tom, I totally agree with you but Woods has fallen down on the job of late. They do not show a subframe for my BX1860, nor for the 2360, but do for the 2660. They do show a subframe for the older BX1850 and 2350, however. I called their tech support line and was basically told if my model wasn't listed, they didn't have a BH for it. The guy basically wanted to get off the phone as fast as he could. Very disappointing. Not totally deterred, I tried working through a local dealer who called and e-mailed Woods engineering. He was trying to get some measurements on the BX1850 sub frame thinking it probably didn't change with the BX1860. After 3 weeks we gave up. He couldn't get a response.
Coincident with all this I got some quotes on trading in on a BX25 and also put my 1860 for sale on CL. I had it sold last week until the guy called Saturday morning and backed out. So, I've now gone to looking up the frame part numbers on the BX1850 and 1860 and low and behold they are the same, so I'm 99% sure it should fit. Nevertheless, if I buy the Woods BH and it doesn't fit, it's my dime to ship it back plus pay restocking fees. An expensive mistake albeit a remote one.
I could trade in my 1860 next week to get the current Kubota 0%/60 month deal, but the trade in quotes would leave me feeling a little used.
Oh, by the way, for anyone considering the Woods unit, it now comes with bosses formed into the dipperstick for a pin on Woods thumb, which I like better than having to get a bolt on one for the BX.
Decisions, decisions. Stay tuned.
Tom, just looked at your pic's. I've searched the board for all the Woods BH6000 threads but didn't see these pic's. Thanks for linking. Do you have to take the bucket off every time you remove the BH? I'm not quite getting why you need the castors on the bottom of the stabilizers? Since you already have the frame on a moveable platform, can't you get it aligned before you drop the stabilizers to lift it up?
/ Woods BH6000 on BX Question #12
Woods definitely has some holes in their application information. I had the same problem trying to figure out if I could get a subframe from them to put my BH6000 on my old B2400. After a visit to my dealer, he was able to get ahold of their tech support and find out it used the same subframe as the 7510, 7610, etc. Unfortunately, sometimes you've gotta do a fair amount of homework on your own....... and not just with Woods.
I will say that the BH6000 is a great backhoe. As you suspect, the 'float' on the main boom is a fantastic feature !!
/ Woods BH6000 on BX Question #13
It does take a couple of minutes more to take the bucket off, but I just use some lynch pins that I've reshaped instead of threaded bolts to hold the big pins in place. It's pretty fast that way. I would never tell anyone they need to do it the way I did, but this works for me. I find there is a real learning curve to getting this bh on the tractor and having nothing touching the ground except wheels just makes it so much easier for me to make very small positioning adjustments and align the thing just the way I want it. I can move the end of the boom and I can also not scratch the concrete. Once it's off, but hydro still attached, I put that 2x4 on, unhook hydro, and she rolls easily away.
As far as the subframe and the rep you talked to, it seems like some people just don't get it: courtesy and helpfulness to the customer results in more sales, which results in the likelihood that your job will not go away and that you will be the one holding that job as well. I'd get his name, then ask for his supervisor. Tell the supervisor what you told us then ask whether you can pay them a few bucks to trace a paper template of the sub-frame, roll it up, and mail it to you.
Hope this helps
/ Woods BH6000 on BX Question #14
Tod, thanks for the pic. I would definitely need to buy or make a backhoe and loader dolly so I could move each to a corner of my shed where it would be impossible to mount or dismount them, but it wouldn't work if the stabilizers had to be down. I would guess the BXpanded BH dolly would work for the Woods hoe and if not, I'm sure it would with a little modification. .
I haven't had an opportunity to check out the Woods backhoe but there are at least two guys using our BXpanded dolly with it. I haven't heard that they had to make any mods.
/ Woods BH6000 on BX Question #15
Aside from the backhoe have you ever wanted to upgrade your tractor? If you put a backhoe on and and then try to upgrade it will hurt! When I sold my BX24 the BH "seemed" to affect the price of used tractors only 3k or so. I talked myself out of selling my BX for a while and in that time I added $1000 worth of skid plates, chains, wheel spacers and a brush fork. When I sold the tractor I passed these along but I might as well have thrown them away. I did not need to upgrade from my BX and you wont need to either if you get a BH put on your 1850. I just woke up one day and realized I really wanted a bigger tractor so I got one.
/ Woods BH6000 on BX Question #16
That's a really good point. If you think that you will want a bigger tractor, maybe a B series, in the future, you will do much better to trade up now. If you add the Woods to this BX, then trade, you will lose money. On the other hand, trading to a bigger BX at any point will not gain you much performance at all and you are better off just putting the Woods on the tractor you have.
Towable Centrifugal Water Pump (A59228)
Towable...
2019 Big Tex T/A 16FT Utility Dump Trailer (A59230)
2019 Big Tex T/A...
2014 Jeep Grand Cherokee SUV (A59231)
2014 Jeep Grand...
Auger Drill Bit Skid Steer Attachment (A59228)
Auger Drill Bit...
2019 Deere 35G (A53317)
2019 Deere 35G...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
