Backhoe Woods Backhoe
/ Woods Backhoe #1
a05883
East Central Wisconsin
Kioti NX 5010, Bobcat ct230
I am looking at buying a woods bh80x backhoe for my tractor. I was told I need a hose kit to connect to tractor. My question is since I have a set of rear remotes can't I just hook it up to them?
/ Woods Backhoe #2
Yes you can. Mine is hooked up to port A and return thru my oil fill tube.Yours would be the same..
/ Woods Backhoe #3
I believe Woods would like to sell you a very specific hose kit, precisely the CORRECT length for hooking up. And a little to short when you can't easily maneuver your tractor to it after the BH has "slipped" a little from where you dropped it. I could have gladly used an extra 6 inches on each hose on my BH70X.
/ Woods Backhoe
I believe Woods would like to sell you a very specific hose kit, precisely the CORRECT length for hooking up. And a little to short when you can't easily maneuver your tractor to it after the BH has "slipped" a little from where you dropped it. I could have gladly used an extra 6 inches on each hose or my BH70X.
Does it seem reasonable that the kit would cost $290 if it only was two hoses?
/ Woods Backhoe #5
Well, I wouldn't be surprised at that price. Ever blown a hose and go to a hydraulic shop and have a new one made?? When I installed my BH-80X I just had a local shop make me two hoses for my backhoe loop...... it was around two hundred dollars for the pair of hoses. That was several years ago.
/ Woods Backhoe
Thanks for the responses.
One more question. I am trying to decide between a 7 qnd 8 foot backhoe. Just wondering why you chose the hoe you did, and would you buy the same if you had to do it over again?
/ Woods Backhoe #8
$35.00 can get you a hand made hose 4foot long at the dealer here. Sure are proud of their hoses.
/ Woods Backhoe #9
You need to let us know more about your tractor, make, model, hydraulic GPM rating, does it have a necessary FEL?
A starting criteria for you is to go online to the Woods site and research which BH model offers a subframe specifically designed for your tractor. That will tell you what Woods would recommend.
One nice feature now being offered by Woods on the BH80-X is an optional factory installed hydraulic thumb.
I have the BH90-X with hydraulic thumb and 4-PT subframe on my NH TC-40.
:welcome:
/ Woods Backhoe
I have a Bobcat CT 230 w/loader. 12.7 GPM flow rate. I know that woods makes a 4 point subframe to fit my tractor. I've already talked to them. I was just looking for peoples thoughts on 7 or 8 ft. It's probably just like horsepower. Can't ever have too much!
/ Woods Backhoe #13
Not really.
The dealers tried to talk me out of my BH70-X for my my B7610, too big. Admittedly I can probably change the tires by swinging it from a tree using the hoe.
If I had planned staying with the B7610 as my only tractor it probably would have been a waste of $$ But now I'm getting ready to get a bigger tractor, while keeping the B7610, and am looking at getting one which Woods makes a subframe for. 1 hoe for 2 tractors.
If you can forsee getting a bigger tractor get the bigger hoe.
(2) 21.5L-16 TIRES W/8 LUG RIMS (A62130)
(2) 21.5L-16 TIRES...
2013 International WorkStar 7400 4x4 Altec AM55E 56ft. Bucket Truck (A61568)
2013 International...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63118)
Snap-On Gold Medal...
2022 JOHN DEERE 325G SKID STEER (A62129)
2022 JOHN DEERE...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
