woods 9000 hoe
/ woods 9000 hoe #1
kully
upper ny,and long island
kubota m4900 with loader
looking at hoes like the bradco 511 and the woods 9000. the bradco is very hard to get up on. it has no step and you have to put down the outrigger to climb up on , has a lot of power but not user friendly. the woods is user friendly and also has brand new sub fram 4 point mount that does not loose ground clearance . the way it mounts is it wraps around rear axel not like the old style that hangs under the tractor .does anybody have any info on how good these woods 9000 hoes are ,and the bradco 511.
/ woods 9000 hoe #3
I have a woods 7500 on a CK30 that I got early summer.
The hoe works great, the 4 pt connection is real nice.
/ woods 9000 hoe #4
I've had a 9000 on my L3130HST going on three years now. No complaints but wish it had a QA bucket like on the big boyz.
/ woods 9000 hoe
do these hoes have power I mainly need it for stumps and rocks I was thinking of the 12in bucket for that and a 24in for just digging.have you the new 4 point hookup, do you have to remove the 3 point set up
/ woods 9000 hoe #6
I have a full sub frame, very first one, that ties into the Woods loader subframe. This is a 4 point connection. It has plenty of power, haven't even used the power mode. That adds another 1000lbs of force. Probably usefull or perhaps needed in rocky soil or tuff roots?
The sway arms need to be unbolted. Then use a rubber strap to hold the 3pt and sway arms together in the middle. Don't have to actually remove anything from the tractor
It was used mostly while building the house using 12 and 24" buckets. Put in a couple septic tanks/drain field, culverts, electrical, water, sewer lines, drain tile, stumps, french drains, planting trees, general excavation etc..
2020 BERGMAN C815S ARTICULATED DUMP TRUCK (A65053)
2020 BERGMAN C815S...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2012 Peterbilt 337 S/A 17ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
