Rear Finish Mower woods 60inch rear finish mower
   / woods 60inch rear finish mower #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i have a woods RD6000-2 finish mower, the middle blade stops when i hit thick grass? the outer blades mow great: was going to order a new belt: removed the one on the mower, it measures outside 117 inches: the two places i checked for belts, one says 118 and the other 119 inches:?? the part number is 1001244: any suggestions? i sharpened the blades and it didn't help.
   / woods 60inch rear finish mower #2
Can you rotate the middle blade easily (without the belt mounted)? If the blade is even a bit stiff to move, a belt isn't going to turn it...the belt will slip.
The other possibility that comes to mind is a worn out pulley.
But the first place I'd look would be the tensioner...make sure there's adequate tension on the belt.
thanks for the reply, i should have torn into it before i posted: the pulleys are held on to the spindle with two 1/4x20 bolts: and they were both sheered off: i have the pulley off now, going to a machine shop in the morning to see if they can drill them out: bought this thing last week for $500, an it looks almost new...the driveshaft doesn't appear to have hardly been used: but they bought a brush hog to replace it, and let it sit in the weeds for 8 years: now i know why. shouldn't be a hard fix: even if i have to buy a new pulley.
   / woods 60inch rear finish mower #4
You found exactly what I was going to suggest you look for. I have a Woods 84" and my right hand pulley (as you look at it from the rear) has a LOT of holes drilled and tapped.
Right now I only have one set left before I need to have the old studs burnt out or get a new pulley.
What I'm saying is have a few more sets of holes drilled and tapped while it is out. It makes for a lot quicker repair should/when it happens again.
good point: i priced a new pulley, @ $45 plus shipping: i will check today and see if its cheaper to just order a new pulley than have these two 1/4 inch bolts drilled out:
ordered new parts: pulley and bushing that goes in it: about $80 with shipping: since i bought the mower for $500, its still a bargain:
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
