woods 60 vs. 600?
/ woods 60 vs. 600?
most any slip clutch needs to be broken loose before you use it or it may not slip at all, as has been stated already. They tend to rust solid and then will not release when they should. If you are doing nasty work with a slip clutch implement loosen up the clutch enough to let it slip and burn off the rust (don't burn it to the ground here, but get the rust worn off) or it may not protect the pto drive when it should.
/ woods 60 vs. 600? #12
Answer for Woodbeef
The blade pins on your M4 should drop right out after removing the holddown clips and keyhole blocks. Generous quantities of heat & beat will help. Never-sieze on the way back together. Good luck.
IRanch IRET13 Mini Tricycle w/Charger (A60463)
IRanch IRET13 Mini...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
John Deere 6 Row Do All (A60462)
John Deere 6 Row...
2018 Kubota B2301 (A60462)
2018 Kubota B2301...
New Holland 3930 (A60462)
New Holland 3930...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
